GSR ENGINE REBUILD HELP
Old Apr 1, 2005 | 01:51 PM
DelSol-B-18's Avatar
Default GSR ENGINE REBUILD HELP
I have a 98 GSR came in my del sol when i bought it
How can i tell what ECU its running? I think it is the stock del sol v tec model, I had a diagnostics on it and had to use the del sol vin to read it...
But my main problem is i need to put my enigne back together, I need tourque specs, on whole top end of motor and line diagrams.. vacuum lines etc..
Yes i did a couple searches didnt fine nething..
Thanks..
Old Apr 1, 2005 | 02:12 PM
TeamNextGenChris's Avatar
Default Re: GSR ENGINE REBUILD HELP (DelSol-B-18)
look at the ECU(it's in the passenger kick panel.behind the carpet).it will have a sticker with a long number on it.in that code will be a three number part.it will say "P72" if it is a GSR ECU,or "P30" if it's a DOHC VTEC Del Sol ECU.
for all the torque specs and other info,get a good shop manual.you will need it-asking for every spec online is no way to get it done.
http://www.helminc.com/helm/homepage.asp?r=
Chris
Old Apr 1, 2005 | 02:31 PM
Thanks, I got a HANES manual on order, thought imight find some info on here..
SHould i change this ecu????
What would be the BEST to use?
Old Apr 2, 2005 | 07:42 PM
Default Re: (DelSol-B-18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSol-B-18 &raquo;</TD></TR><TR><TD CLASS="quote">
What would be the BEST to use?</TD></TR></TABLE>
for the B18C1,a P72 would be best.
Chris
Old Apr 2, 2005 | 07:54 PM
delslo93's Avatar
Default Re: (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">for the B18C1,a P72 would be best.
Chris</TD></TR></TABLE>
Not necessarliy....you could get a PO6 or a P28 converted to a P72 with uberdata and all with all the specs you wanted including rev. limit where u want it and launch features. Or just get the one you have chipped and your off.
Old Apr 2, 2005 | 07:56 PM
Default Re: (delslo93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delslo93 &raquo;</TD></TR><TR><TD CLASS="quote">
Not necessarliy....you could get a PO6 or a P28 converted to a P72 with uberdata and all with all the specs you wanted including rev. limit where u want it and launch features. Or just get the one you have chipped and your off. </TD></TR></TABLE>
for a stock motor though,the stock program is probably the best route.no need to go to all the trouble of chipping other ECUs to the P72 specs.
Chris
Old Apr 3, 2005 | 08:30 AM
delslo93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">for a stock motor though,the stock program is probably the best route.no need to go to all the trouble of chipping other ECUs to the P72 specs.
Yeah your right but what i was saying is if he didnt have a P72 right now its probably cheaper to get the one he has converted than to buy the P72.
Old Apr 3, 2005 | 08:59 AM
tilt's Avatar
Unless I'm missing something, that would not support the IAB.
Old Apr 6, 2005 | 06:45 AM
All i got done is CAi , header, exaust MSd ignition system, so what should i do to get the most out of the engine....
FLAASH
12
Jun 3, 2011 04:42 PM
Kaeon
Jul 3, 2008 05:25 AM
BeaverLiquor
Apr 2, 2007 03:17 PM
