oil temp guage???
you can run one but it is not required, it is only important when you are running a road race setup and you have to moniter oil temp. Oil is always close to your coolant temp since coolant flows through out the block and is cooling the oil as well. i dont know anything about your setup but if your boosting above 25psi and run your motor around redline alot i would tell you to get a guage but in any other case i would not.
MattD@Stoptech
14
Aug 6, 2002 10:46 AM
