Distributor Pain
Old Apr 1, 2005 | 10:45 AM
Ricta's Avatar
Default Distributor Pain
Yeah my car has been running shitty for the past 2-3 weeks like it will be fine when it cools down for around 1 day but then ill drive it for about 1-2 miles and it will start puttering real bad unless i very gently baby the gas if i go anymore it will start to putter real bad and my car will shake. Also for ex. im in second gear @ 20mph and i slam on the gas it will putter all the way up until 40mph then it will run normal but reving high (i have a civic hb cx so my car never came w/ a tach or id tell you the RPM's :\). So far ive replaced Spark Plugs, Fuel Filter, Plug Wires, Distributor cap/rotor, used fuel injector cleanrer and replaced my oil cause it was very low. So im thinking that my distributor went bad so i went to a junkyard and they said i need a CX distributor and that any other one wont work. But they didnt have any, so would anyother distributor hook up to my engine? TY
Old Apr 1, 2005 | 11:21 AM
Ricta's Avatar
Default Re: Distributor Pain (Ricta)
Old Apr 1, 2005 | 12:23 PM
Ricta's Avatar
Old Apr 1, 2005 | 02:15 PM
Luserkid's Avatar
Bump because i might have the same problem as you.
Old Apr 1, 2005 | 07:13 PM
Ricta's Avatar
Default Re: Distributor Pain (Luserkid)
^BUMP FOR NEEDING HELA HELP!
Old Apr 1, 2005 | 10:21 PM
PupaScoopa's Avatar
So for the first few minutes, it idles fine and revs fine under load and no load? When you say after it cools down for one day: if you drive it, it gets bad, let it sit until it's cold (1 hr or so): will it run fine for a few minutes or still crappy?
Old Apr 1, 2005 | 10:25 PM
JDMlyfestyle's Avatar
take your dizzy cap off and remove the rotor and cover. you will see your ICM (Ignition Control Module) it has 4 connectors on it. has 2 screws holding it in. write down what plugs go where on the ICM. then take the ICm to your local parts store and have them test it.
I had the a similar problem and i took mine out and took it to advanced and that damn thing was dead. brand new one will set u back around $60.
ratchetEDsedan
14
May 30, 2017 07:08 PM
Dan16z6
Jan 4, 2016 03:19 AM
EsCo_EsCo
Sep 29, 2008 08:25 AM
xtuckerx
Mar 15, 2007 03:23 AM
88crx-si
Jun 18, 2005 08:17 PM
