WOW goin to fast but then goin 0 MPH
hey i have a b18c1 and **** is causing me problems...
here a pic i know it will help out alot...
do i need to pull out my motor and tightin it up or i dont have t0o...
if thats tightin up an dmy MPH doesnt work what should i check
i give u props for taking the motor swap into ur own hands but it can be dangerous if u dont know anything about how an engine and its components work.
wait so you gong to pull the entire engine to tighten the a/c pulley.... thats a little extreme no?
just get a wrench of the dam thing and tighten it....
but i guarantee that will have no effect of your speedo.
...he just a found a pic of the motor so he could show you whats pulling out...although he didnt do the best job of it... he hasnt pulled the motor YET, hes asking if he should..........
That's your a/c compressor, there's no need to pull the engine out to tighten the pulley. And it doesn't effect the speedo.
If you can't get at it in position, take off the belt, take out the 4 bolts holding it on and pull it back, don't disconnect the pipes though.
Is the speedo operated electronically or is it a cable type? the cable might be loose if it is a cable type, check it where it goes into the 'box and at the back of the clock. If it's electronic, check all the connections and the speedo unit on the 'box.
good luck.
good luck.
thanx guys well i think the squekinng of my belts is my A/C pulley then.. if you search for alternator sound or something youll see i had that problem... but thanx for that one.. but i didnt pull out my engine i just found a pic to make things eazy for you guys.. ill check for my fuse. wiring. and stuff.. the thing im thinkin bout is the people who put my alarm disconnect something or whatever.. thanx again.. db8 GEEZER
