IMPORTANT BOOST QUESTION
Old Mar 31, 2005 | 07:25 PM
tr123gone's Avatar
Default IMPORTANT BOOST QUESTION
i wanted to get ur guys opinion on my setup i have a stock B20b block with a gsr head with ctr cams and skunk2 manifold. Now im putting on my complete drag kit
and tuning it for 11psi. Do u think that setup will hold that amount of boost? if so what numbers do u think i will be putting?
Old Mar 31, 2005 | 08:16 PM
tr123gone's Avatar
Default Re: IMPORTANT BOOST QUESTION (tr123gone)
I ALSO HAVE 550 INJECTORS. I NEED FFED BACK FROM U GUYS LET ME KNOW
Old Mar 31, 2005 | 08:17 PM
1FastCoupe's Avatar
250-260ish WHP
Old Mar 31, 2005 | 08:22 PM
Evo-man@20psi's Avatar
At least 250 but could be much more its all about the engine mgmt
Old Mar 31, 2005 | 08:31 PM
SSBPGSR's Avatar
Default Re: IMPORTANT BOOST QUESTION (Blue00vtecsi)
what u using to tune it?
Old Mar 31, 2005 | 08:33 PM
tr123gone's Avatar
I WAS THINKING WAY MORE BECAUSE MY FRIEND HAS A STOCK GSR WITH CTR CAMS TUNED FOR 10PSI DOING 330 WHEEL POWER SO I WAS HOPING TO BREAK AT LEAST 380
Old Mar 31, 2005 | 08:35 PM
redline300z's Avatar
good luck getting stock b20 sleeves to handle 380 whp, which you arent going to make on 11psi
Old Mar 31, 2005 | 08:44 PM
tr123gone's Avatar
Default Re: (redline300z)
SO IF ITS POSSIBLE TO MAKE 330 ON STOCK GSR WHY COULDNT I MAKE THAT ON A B20B VTEC WITH CAMS
Old Mar 31, 2005 | 08:45 PM
tr123gone's Avatar
Default Re: (tr123gone)
I HAVE HEARD FROM A MEMBER ON HT DOING 10 PSI ON STOCK B20
Old Mar 31, 2005 | 08:48 PM
Race Egr's Avatar
B20 sleeve's suck save yourself the headache and get it sleeved
Old Mar 31, 2005 | 08:57 PM
SSBPGSR's Avatar
Default Re: (NAPIER)
sure as hell arent getting that kinda power with a straight t3
Old Mar 31, 2005 | 08:59 PM
turboEGhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr123gone &raquo;</TD></TR><TR><TD CLASS="quote">SO IF ITS POSSIBLE TO MAKE 330 ON STOCK GSR WHY COULDNT I MAKE THAT ON A B20B VTEC WITH CAMS</TD></TR></TABLE>
You could, but you're not going to make 380 at 11 psi, and you arn't going to make it reliably on those thin sleeves.
Old Mar 31, 2005 | 09:02 PM
tr123gone's Avatar
THANKS FOR THE FEEDBACK EVEYONE, KEEP THEM COMING
Old Mar 31, 2005 | 09:04 PM
tr123gone's Avatar
AM I BETTER OF DOING AN LS VTEC SETUP?
Old Mar 31, 2005 | 09:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tr123gone &raquo;</TD></TR><TR><TD CLASS="quote">AM I BETTER OF DOING AN LS VTEC SETUP?</TD></TR></TABLE>
IMHO, yes. You'd also be better off turning off caps lock, it doesn't do much except irritate most people.
Old Mar 31, 2005 | 11:10 PM
NotUrAvgSi's Avatar
CTR cams on a turbo set up. I heard that does cams are not that great for a turbo set up. cam lobes are too big. 00 ITR cams probably would be better. ctr cams are good for NA.
Old Mar 31, 2005 | 11:11 PM
SSBPGSR's Avatar
Default Re: (NotUrAvgSi)
auto b16 cams
Old Apr 1, 2005 | 01:52 AM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">B20 sleeve's suck save yourself the headache and get it sleeved</TD></TR></TABLE>
Yep they do.
liam
Old Apr 1, 2005 | 10:08 AM
tr123gone's Avatar
thanx for the feed back
Old Apr 1, 2005 | 10:18 AM
wantboost's Avatar
Who is Mr Robot?
liam, do you know the circumstances of those sleeves cracking? like psi levels, etc?
chasered07
Apr 21, 2010 11:23 AM
ivan93egreppin210
Aug 9, 2008 10:25 AM
del_orson
May 27, 2007 11:21 AM
jdm92teg
Nov 8, 2005 08:52 AM
2SLO
Apr 27, 2002 08:40 PM
