Will my motor be okay?
Old Mar 31, 2005 | 10:04 AM
dt4life's Avatar
Default Will my motor be okay?
I have a 94 GSR with 116k miles on it. It runs perfect right now. I have a set of Toda Spec Bs, the valve train, cam gears, timing belt, new water pump, tensioner pulley, type r oil pump, vafc, chipped p28. Do i need to replace my bearings in the block? Or should it be fine to rev up to 9500?
Old Mar 31, 2005 | 11:32 AM
SiRLudeVtec's Avatar
Default Re: Will my motor be okay? (wannaTypeR)
IMO i wouldn't risk taking a motor with 100K+ to 9500RPM.....i say 85000 tops....9500 really puts a load on your engine - unless you rebuild it.....But then again - its a honda/acura so i guess it's really your choice. Good luck though - hope you can do it safely
Old Mar 31, 2005 | 11:40 AM
dt4life's Avatar
Default Re: Will my motor be okay? (ShinAkuma)
I think I'm going to save and send a used GSR block out to exospeed and have them re build it will all oem parts and CTR pistons
Old Mar 31, 2005 | 11:51 AM
dt4life's Avatar
Default Re: Will my motor be okay? (LSVTEC_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC_DC2R &raquo;</TD></TR><TR><TD CLASS="quote">100k + 9500rpms = boom! Why do you want to rev so high? I get new bearings for sure, unless they are still in spec..</TD></TR></TABLE>
I don't think I will go that high but if I'm going to be shifting around 8500 with my spec Bs (thats what I shifted at in my 99 SI that had spec Bs) and I miss a gear, I want to make sure I'll be okay. I wouldn't be shifting at 9500 on purpose.
Old Mar 31, 2005 | 09:05 PM
Evo-man@20psi's Avatar
I would'nt take the chance of reving that high too many miles
Old Mar 31, 2005 | 10:21 PM
UNKNOWN_MEMBER's Avatar
Toda B's don't make power that high.
Old Apr 1, 2005 | 08:23 AM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I have a 94 GSR with 116k miles on it. It runs perfect right now. I have a set of Toda Spec Bs, the valve train, cam gears, timing belt, new water pump, tensioner pulley, type r oil pump, vafc, chipped p28. Do i need to replace my bearings in the block? Or should it be fine to rev up to 9500?</TD></TR></TABLE>
If you want to put the motor through a bit more stress than reg driving, you have to consider the wear and tear of the current engine now. You say it has about 110K miles and that can be a good motor still or it can be on its way out. The main parts that would fail will be the bearings and rings after so many miles. Honda is pretty good with their motors so these things dont usually fail until 200K+ miles and more for a well taken cared of motor.
If you plan on rebuilding the block, all our block packages replace all the wear and tear parts anyways. Bearings, oil pump, rings, and main seal. we also do the proper machine work to prep the block for optimum performance for the pistons to fit perfectly in the cylinders and the rings to seal properly. Crank is also freshly micropolished before the bearings are put on it and measured.
Wil
Old Apr 1, 2005 | 09:27 AM
dt4life's Avatar
Default Re: Will my motor be okay? (exospeedAMcrx)
I've already mentioned you and will have you guys build my motor when funds are available.
Old Apr 1, 2005 | 12:01 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I think I'm going to save and send a used GSR block out to exospeed and have them re build it will all oem parts and CTR pistons</TD></TR></TABLE>
You like insanely high compression?
Old Apr 1, 2005 | 12:09 PM
dt4life's Avatar
Default Re: Will my motor be okay? (Hybrid93Eg)
my buddy ran the same setup and it is CRAZY FAST. I'll just have the motor clayed, it won't be a problem. So many people have been okay with it. Just long as you take care of your motor
Old Apr 1, 2005 | 12:36 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannaTypeR &raquo;</TD></TR><TR><TD CLASS="quote">my buddy ran the same setup and it is CRAZY FAST. I'll just have the motor clayed, it won't be a problem. So many people have been okay with it. Just long as you take care of your motor</TD></TR></TABLE>
12.9:1 compression with a GSR head. There is no need to run that much compression on the street.
Old Apr 1, 2005 | 12:45 PM
dt4life's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
12.9:1 compression with a GSR head. There is no need to run that much compression on the street.</TD></TR></TABLE>
I think it's more of a personal preference, but thanks dad
Old Apr 1, 2005 | 12:49 PM
Hybrid96EK's Avatar
I think it's more of a personal preference, but thanks dad</TD></TR></TABLE>
No problem son. You'll learn from experience. Its a hard lesson, but sometimes its whats needed for some people.
Old Apr 1, 2005 | 01:20 PM
dt4life's Avatar
No problem son. You'll learn from experience. Its a hard lesson, but sometimes its whats needed for some people.</TD></TR></TABLE>
haha whatever dude
r01516
Sep 4, 2008 02:33 PM
nota-eg
Jun 15, 2006 10:26 AM
elpiar
Sep 27, 2005 09:41 PM
IntegraRsLsVtec
20
Sep 14, 2004 06:56 AM
drdavidge
Jun 2, 2002 02:06 PM
