what exactly is involved in an engine rebuild?
Old May 31, 2002 | 07:36 PM
drdavidge's Avatar
Default what exactly is involved in an engine rebuild?
can someone tell me part by part what is involved in an engine rebuild? i think im about to get a 95 gsr with 90k miles, driven by my friends brother who took extremely good care of the car, never ripped it, constant routine maintenence, etc, but i plan on turboing it and wanted to know what was involved in a rebuild, and what should be done to ensure reliability for the next 5 years of me driving to college 20 miles away every day. also, how much should it cost?
Old Jun 1, 2002 | 10:39 AM
drdavidge's Avatar
Default Re: what exactly is involved in an engine rebuild? (drdavidge)
anyone?
Old Jun 1, 2002 | 10:43 AM
KTeller8's Avatar
not 100 percent sure.. but since no one else i jumping in.. i think
new cams, cam gears, rods, pistons, basically the whole bottom end.. the basic short block.. i think. i am not 100% like i said
Old Jun 1, 2002 | 10:55 AM
Darin D.'s Avatar
new rings+hone, rod and main bearings, thrust washers, rear main seal, new oil pump, water pump, timing belt, headgasket. Probably around $600.
But at 90k miles you shouldn't need a rebuild. As long as the engine runs good, just do the timing belt, water pump and oil pump, and a basic tune up and you should be good.
Old Jun 1, 2002 | 10:56 AM
drdavidge's Avatar
Default Re: what exactly is involved in an engine rebuild? (Willis)
even to run boost?
Old Jun 1, 2002 | 11:17 AM
Darin D.'s Avatar
yea
Old Jun 1, 2002 | 01:33 PM
schwett's Avatar
New User
i wouldn't recommend the rebuild described by willis if you're going to turbo the motor. that would be about what's required to bring a stock motor back to new stock condition, but it won't be any stronger, and it WILL cost a lot more than $600.
if you're going to spend the money, do it right with forged internals, sleeves, etc etc
Old Jun 1, 2002 | 01:52 PM
drdavidge's Avatar
Default Re: what exactly is involved in an engine rebuild? (schwett)
whats the whole list of stuff i should do?
Old Jun 1, 2002 | 02:27 PM
dustin's Avatar
Here's some rebuild work I did on an LS motor last weekend:
http://imglib.************/index.cgi?cmd=viewcat&id=205
Old Jun 1, 2002 | 06:12 PM
int3gra's Avatar
Default Re: what exactly is involved in an engine rebuild? (dustin)
http://www.c-speedracing.com/howto/m...ild/build.html
dustin do u have GE sleeves?
[Modified by int3gra, 10:14 PM 6/1/2002]
Old Jun 1, 2002 | 06:17 PM
MoBlack's Avatar
New User
Default Re: what exactly is involved in an engine rebuild? (int3gra)
Are these holes there on the stock crank? Is this from balancing the crank?
http://imglib.************/index.cgi?...wimage&id=4409
Thanks
[Modified by MoBlack, 7:17 PM 6/1/2002]
Old Jun 1, 2002 | 06:26 PM
2K_TEG's Avatar
Default Re: what exactly is involved in an engine rebuild? (MoBlack)
Thanks
the crank comes from the factory with those holes.
Old Jun 1, 2002 | 06:27 PM
2K_TEG's Avatar
Dustin, how long did all that take you? Did you run into any major obstacles? If I buy you a plane ticket, wanna come help me in a month or two?
Old Jun 1, 2002 | 06:36 PM
schwett's Avatar
New User
great pictures!
Old Jun 2, 2002 | 12:32 AM
dustin's Avatar
Default Re: what exactly is involved in an engine rebuild? (2K_TEG)
Stock sleeves. Took about 3 hours. I replaced the main seal and oil pump seal, new main bearings, new rod bearings, plastigauged everything, put the pistons ont he rods, file fit the rings, and tightened everything up. I spent the most time filing the stupid rings, that crap takes forever.
Dustin
Old Jun 2, 2002 | 07:42 AM
hydroflip's Avatar
go until something breaks...then rebuild from there...
Old Jun 2, 2002 | 12:15 PM
jeremyG2teg's Avatar
Default Re: what exactly is involved in an engine rebuild? (hydroflip)
Or he could do it now and skip all the headache and inopportune down time by putting it off.
Old Jun 2, 2002 | 02:06 PM
harryg's Avatar
very interesting pictures
Flightmaster127
May 18, 2010 05:59 PM
JD43
Aug 1, 2008 11:11 AM
gato5254
Aug 2, 2007 02:46 PM
rob42386
Nov 26, 2004 07:22 PM
scuba123
Aug 4, 2004 05:50 AM
