how often should you change ur atf?
Old Mar 28, 2005 | 10:20 PM
jay's racing's Avatar
Default how often should you change ur atf?
on my gsr i change the honda mtf every oil change.
should i do the same for my beater with an auto tranny?
Old Mar 28, 2005 | 10:25 PM
CB7VTEC's Avatar
Default Re: how often should you change ur atf? (intellectual.)
change it at least once a year at the max, but id change it at least every 6 months. its the only thing that will really prolong the life of that trans.
Old Mar 28, 2005 | 10:31 PM
Default Re: how often should you change ur atf? (CB7VTEC)
well 2 oil changes before i changed the atf in it. now the shifting is becoming hard... and sluggish. and i feel im losing lots of power between 1-3 rpm's?
Old Mar 28, 2005 | 10:53 PM
help!
Old Mar 28, 2005 | 11:17 PM
130R's Avatar
u should change every other oil change imo
Old Mar 29, 2005 | 03:25 AM
james p.'s Avatar
Default Re: how often should you change ur atf? (carbing'ed)
My EK service manual says to change the auto tranny fluid every 80,000km
it's a 2k EK 1.4 auto grocery getter
Old Mar 29, 2005 | 05:00 AM
dip-set's Avatar
Default Re: how often should you change ur atf? (james p.)
is there drain plug on the auto tranny like the manuals, to drain it, then just refilling it with mtx fluid and all is well?
Old Mar 29, 2005 | 06:27 AM
mct121's Avatar
Default Re: how often should you change ur atf? (dip-set)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dip-set &raquo;</TD></TR><TR><TD CLASS="quote">is there drain plug on the auto tranny like the manuals, to drain it, then just refilling it with mtx fluid and all is well?</TD></TR></TABLE>
There is a drain plug on the passenger side through the wheel well. I can get to it with the wheel on my 2000 LX. The fill port is where the tranny dip stick goes. I would recommend Honda automatic transmission fluid, as the manufacturer does, not manual transmission fluid.
Also, I don't see any problem with changing every other oil change if you want, but the recommended period is every 30k miles. Every other oil change may be excessive. I do mine every six months.
IMHO
Old Mar 29, 2005 | 06:28 AM
mistersparco's Avatar
washuuu
Default Re: how often should you change ur atf? (mct121)
What about the filter?
Old Mar 29, 2005 | 06:29 AM
mct121's Avatar
Default Re: how often should you change ur atf? (mistersparco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mistersparco &raquo;</TD></TR><TR><TD CLASS="quote">What about the filter?</TD></TR></TABLE>
No filter on this transmission.
Old Mar 29, 2005 | 06:36 AM
dip-set's Avatar
much appreciated..
Old Mar 29, 2005 | 02:04 PM
130R's Avatar
an older honda auto tranny wont last 30k without changing out the atf.
honda can build the best parts, and the worst parts at times
Old Mar 29, 2005 | 02:10 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intellectual. &raquo;</TD></TR><TR><TD CLASS="quote">on my gsr i change the honda mtf every oil change.
should i do the same for my beater with an auto tranny?</TD></TR></TABLE>
Unless you drive your car outrageously hard, changing your mtf every oil change is an extreme over kill!!!
Old Mar 29, 2005 | 02:16 PM
130R's Avatar
Default Re: how often should you change ur atf? (walker111)
it's not extreme overkill. it's not like ur doing anything bad to ur car
Old Mar 29, 2005 | 02:46 PM
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed &raquo;</TD></TR><TR><TD CLASS="quote">it's not extreme overkill. it's not like ur doing anything bad to ur car</TD></TR></TABLE>
True, but your wasting money. Me changing mine every 10-15k is just as good as you doing it every 3k. I guess if you got money to throw away, knock yourself out but that money could be used other places.
Nooch
Mar 20, 2011 06:37 AM
JDM H22
Mar 14, 2006 12:12 PM
sony224422
Jan 13, 2006 05:33 AM
BeBe
May 10, 2004 03:31 PM
yaya
Nov 6, 2003 11:22 AM
