Need help getting my car started
Old Mar 28, 2005 | 04:46 PM
Bird333's Avatar
Default Need help getting my car started
Ok, I got a '88 Civic hatchback that has a dead battery. It has been sitting up awhile but I had been jumping it off every so often. Well eventually it ran out of gas. So I put some gas in it and tried to jump it off again and it wouldn't start. So I did the test to check for a bad fuel pump. The following results were with a DMM (set on DC) touching the positive probe to the yellow/black wire on the connector under the back seat and I touched the negative probe to the black wire.
1. With the key in the 'on' position, the battery cables connected to another car for power and a jumper (pins 5 and 7) placed on the main relay connector; I got -14.9mV reading.
2. With the key in the 'on' position, battery cables connected and NO jumper; I got -14.7mV. Almost exactly the same with the jumper. Weird.
3. With NO key in the ignition, battery cables connected and NO jumper; I got 0.1mV.
What readings am I supposed to be getting with this test? Another thing that was kinda strange was that the connector under the back seat had 3 positions for pins (yellow w/black stripe, black, yellow w/white stripe all side by side) instead of 4 positions (2 on top and 2 on bottom) like the picture in the manual. I am 99% certain I got the right connector though because there isn't another one in the area at all.
Suggestions?
Old Mar 29, 2005 | 06:08 AM
Bird333's Avatar
Help. Shouldn't I be getting different readings with the main relay jumped than without?
Old Mar 29, 2005 | 09:27 AM
crxtreme89h's Avatar
Default Re: (Bird333)
So does the fuel pump kick on when you turn the key to the On position before you start it?
Old Mar 29, 2005 | 10:28 AM
Bird333's Avatar
Default Re: (crxtreme89h)
I didn't hear anything. I'll hook the main relay back up and check again. It still concerns me that I get basically identical readings when I have the main relay jumpered and when I don't.
Old Mar 31, 2005 | 04:49 PM
Bird333's Avatar
I didn't hear anything so I guess it's the fuel pump???
Old Mar 31, 2005 | 05:04 PM
90HcDxR's Avatar
well not exactally, What kinda of noise does your car make when u turn your key? is it trying to turn over but it just wont, is there a clicking sound? does it make no noise at all?? these are important questions because it will help us help u. Now im sure your a pretty smart kid but check all your wires that have to do with the battery(EX:positive wire,negative wire, starter wire, your wire that connects from your engine fuse box to your pos. battery cable). The only reason i say this is because Sometimes even I tend to overlook the small things because it doesnt seem realistic that i would forget them but, it happens. My car had almost an identical problem and all it was was that my wires werent tightened down enough to the fuse box&battery. not to add that my battery was COMPlETELY DEAD. check those things out then go from there.....always remember when trying to solve a problem u must start from the begging.
Old Mar 31, 2005 | 07:28 PM
Bird333's Avatar
Default Re: (90HcDxR)
The battery is dead. I had been jumping it off. It does sound like it wants to start but it just won't catch.
Old Apr 1, 2005 | 08:08 PM
Bird333's Avatar
Any other thoughts?
Old Apr 2, 2005 | 04:20 PM
Did you try a different relay? It's been a couple of days since I wrote you. What have you tried since then?
yeaBuddy
Apr 11, 2011 03:49 AM
AJWatUC
Jul 12, 2007 05:56 PM
egcivic
Nov 24, 2006 02:53 AM
Heavy Pee
Jul 21, 2003 08:32 PM
