Beware of Dynotuned in Madison Wisconsin!! They are scammers!!!
They tuned my car on the dyno and blew my 4th cylinder in the 1st run!! and then they told me it was ok to drive home and the motor blew up on the way home. and now they wont do a thing about it. they are total scammers
Modified by importguy220 at 12:00 AM 3/29/2005
Ive herd some sketchy things about them. Thats why I went down to Ill and got it tuned by dave at the whipfactory.
Although Im sure they probably have a sign or waver to sign that says they are not responsible for problems caused by their tuning/ dyno runs.
I don't know what is going on here with missing post bodies. But in all fairness, let me explain. When the kid brought the car here it was barely running and most likely had 0 compression on #1 cylinder when he brought it here. We did a pull on it and shut it down after vtec hit with stock ignition timing and cam gears set on 0 on both intake and exhuast cams We did not do any of the work on this car He had someone else put cams and cam gears in it and we were supposed to tune it. We decided there was something wrong with the motor and did a compression test and found compression to be low on three cylinders. With #1 being at zero. he drove it here this way and so he tried to drive it home. In no way are we responsible for him blowing his motor up on his way home! Sorry to hear that it blew up on the way home.
Ur such a Jack ***... don't blame dynotuned when ur car was Fucked up in the first place. Dynotuned tuned my car.... 285hp 189 tq @ 5 psi and i've been driving it ever since... I don't see anything wrong with mine. Not to mention they did work ON MY CAR. This is what i recommend stop letting wack jobs like u work on cars.... take it to someone who knows. THANKS TO DYNOTUNED PERFORMANCE!
whoa whoa whoa buddy, where do you get off blaming it on them. if on the first pull it went bad? those guys have done all the mechanical work on my car, did my LSVTEC, that now has over 12,000 miles on it, which everyone told me was impossible, and ive been spraying it to boot. if you bring them a car that is runnug like hell, and 1st off, sign a waiver to dyno it, and it blows on the first run, id say thats owners responsibility, or whoever built the motor, or did the mechanical work. in no way would that be tDynotuned's fault!!
<U>DYNOTUNED PERFORMANCE IS NOT A SCAM SHOP, THEY HAVE 2 ASE CERTIFIED MECHANICS!! DONT BLAME THEM FOR SOMETHING THEY DIDNT DO!!</U>
THANKS AGAIN TO DYNOTUNED PERFORMANCE!!
BTW- now do you think they will want to help you at all??
They did all the work on my current Car that dynoed at 260+ whp on 7psi on a stock gsr motor! They tuned my other hatch that i sold and is still running to this day! Curt and all the guys at dynotuned Performance know there **** and in any way it was there falt they would have done what it takes to make it right!
<FONT SIZE="7">ALL MY WORK IS DONE BY DYNOTUNED PEFRORMANCE
AND MY CAR RUNS GREAT</FONT>
97crxdelsol, is a trial member and has reached his 5 post limit, so he asked me to tell you that.... its stock gsr bottom end stock compression.... cometic head gasket (a little thicker than stock).... skunk 2 manifold..... and hondata <----with dynotuned tuning the hondata.... ran a best of 13.1 @ 108 on 5 psi, before tuning!!
and if that not good enough, you can find the guy somewhere in Iowa, that got his car tuned by curt, started with like 170 somethin whp, on a fully built b16 with a turbo kit, when it left i think it was making just barely under 400whp
Curt and all the guys at Dynotuned have not only been very supportive in helping me fix my car numerous times for things that the jackass that owned it before me Ghetto-Rigged, but have also begun to do Tuning and everything in my car runs perfect!
DYNOTUNED PERFORMANCE IS THE SHIZNITE!!!!!<U></U>
importguy220
Mar 29, 2005 02:49 PM
Mr Hammond
27
Oct 25, 2003 08:39 AM
