dyno tuning steps
Old Nov 7, 2002 | 10:52 AM
Doctor CorteZ's Avatar
Default dyno tuning steps
getting ready to start tuning the kaa.....
not sure what works best in what order.
so post your suggestions / tips / problems when you've tuned a car , anything that works good , anything that works bad.
parts to tune are -
VAFC
cam gears
timing
FPR
thats it , I know there is a logical order to tune these in so post what works best for you.
TIA --
Old Nov 7, 2002 | 12:05 PM
Default Re: dyno tuning steps (Doctor CorteZ)
nobody tunes their own car ??
Old Nov 7, 2002 | 12:10 PM
google's Avatar
i do but what u got on there first. all electrical comp...afc ...emanage.... and what u got on the cams gears compression and what motor and turbo na
Katman's Avatar
parts to tune are -
VAFC
cam gears
timing
FPR
TIA --
from past dyno experiences this is what was done...
first is a baseline run to see where your power is at its best point and where the power band dies off.
then distributor timing is adjusted; a couple dyno passes are made.
then cam sprocket adjustments are made and passes are made on the dyno to get most juice outta the cams.
then fuel pressure settings are made, a couple dyno runs are done.
then electronic fuel/vtec settings are set, a few more dyno passes are done to fine tune.
depending on what camshafts you have is how long dynoing will take also. I hear Toda B's and Jun cams can take quite a while to fine tune.
Old Nov 7, 2002 | 12:34 PM
Default Re: dyno tuning steps (1320in11)
did you read my post ?
I listed what will be tuned quite clearly....
since when does compression and engine denote what order you tune in ??
Old Nov 7, 2002 | 12:36 PM
Default Re: dyno tuning steps (Katman)
perfect , thats almost exactly the order I would've done , just wanted to make sure.
cams are 00 ITR..... should be nice though.
thanks Jason
Old Nov 8, 2002 | 11:52 AM
Katman's Avatar
np.
Old Nov 8, 2002 | 12:48 PM
RaceTilIDie's Avatar
If you want just an order:
1. Tune the Cam gear first for what you want.
2. If you moved the cam gear, you will HAVE to adjust your timing because the timing will have changed.
3. Tune the FPR.
4. Then tune the VAFC
another option is:
1. Tune the FPR
2. Tune the cam gear.
3. TIming
4. VAFC
But what I would do is tune cam gear, then timing, then FPR, then see if you can get more out of hte cam gear, if you moved the cam gear, readjust timing, then VAFC.
Have Fun!
pacifico
Aug 14, 2004 01:46 PM
ViZ
Dec 10, 2003 01:13 PM
Asahi
Mar 26, 2003 12:45 PM
90accord1
Sep 12, 2002 09:25 AM
