HELP! -> 99 b18c5 into 97ek hatch (choking/bogging issues)
ok, before anybody tells me, i did my search on "choking" and found:
https://honda-tech.com/zerothread?id=820984
and also did my search on "bogging" - but really found nothing that would answer my problem...
i am currently doing a swap: (b18c5 to my 97 ek hatch)
-using chipped P28 (OBD1)
-using jumper harness for ECU (OBD2a --> OBD1)
-using 98 Si harness (OBD2a) - <CANADIAN>
everything seemed to work out fine until i tried my first crank...
the engine will start, and idle fine. but as soon as i hit the gas (just barely) the throttle sounds like it chokes, then dies.
(note)-
-the motor is using my stock 97 ek injectors, since the ones that it came with was leaking
-currently do not have o2 sensor plugged, since i need an exhaust put on
-motor has new spark plugs
-no CELs thrown
can anybody help?
thanks
(note)-
-no CELs thrown
can anybody help?
thanks
thought it was the o2, but we'll see when i get the exhaust done..
and map sensor and tps is not the problem.. cause the motor idles fine... its just when i give it gas, sounds like it chokes and then dies...
thanks tho
anyone else have tips or suggestions?
thanks tho
t-del28
Oct 18, 2012 11:52 PM
gmarchel
18
Nov 3, 2011 07:48 PM
terronb20ek
18
Apr 2, 2011 04:34 PM
