Need help with harness for EK
Old 03-12-2004, 08:48 AM
tegedrex's Avatar
Default Need help with harness for EK
Trying to swap a GSR in an EK hatch, ? I have is what harness would you go with I have an 99 SI but not sure if it will work. SO what should I use SI, EX or what? Thnx
Mr Boston's Avatar
Default Re: Need help with harness for EK (tegedrex)
Use the 99 Si harness you have
Old 03-12-2004, 08:53 AM
tegedrex's Avatar
BTW the hatch is an 97 if that means anything
Old 03-12-2004, 10:21 AM
djickabod's Avatar
I have a 97 hatch and just dropped in a 00 B16a2. This is how I did my swap after I called Jotech in Garland,Tx for help.
96-98 civic is a OBD2a setup. And the 99-00 B16a2 is a OBD2b set up. So I used a 97 OBD2a GSR ecu with my STOCK DX Harness. I wired up the Vtec Sel., Vtec Press. O2 Sen., and the Knock sen. Now I have no problems. Now if you want to use the P2T Si ecu it can be used. But if I were you I would go with a P28 and a Skunk2 jumper. I plan on buying a P28 here soon.
Old 03-12-2004, 10:22 AM
djickabod's Avatar
Default Re: Need help with harness for EK (djickabod)
I also have a OBD2 GSR Harness for sale if you need it. Ill take $100 shipped for it.
ek fan
05-27-2008 09:25 PM
cdrick_pha@hotmail.com
04-30-2008 05:56 PM
keogsr1
05-16-2007 11:29 AM
redboost10
02-08-2005 08:20 AM
Quick Reply: Need help with harness for EK
