Suspension & Brakes Theory, alignment, spring rates....
INNER TIE ROD HELLLP!!!
Old Mar 27, 2005 | 06:59 PM
SpoonFedHatch's Avatar
Default INNER TIE ROD HELLLP!!!
car: 1995 acura integra
power steering/5speed
ok, so my passenger side tie rod/ inner tie rod is wiggling back and forth. Whenever i hit the brakes, or make a slight pass over a bump, it "knocks", and when i inpected the tie rod, it wiggles front to back, whereas the DRIVER side stays stable inside of it's boot
here's a picture of what's wiggling.
basically, i need some detailed descriptions on how to remove this and replace the inner tie rod.
thanks in advance!!
Old Mar 28, 2005 | 08:45 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: INNER TIE ROD HELLLP!!! (SpoonFedHatch)
Anyone ever done this?
Old Mar 28, 2005 | 08:54 AM
Tyson's Avatar
read thru these two threads. they address different problems, but the procedures are the same to separate the inner tie rod, and help seperating the outer tie rod.
https://honda-tech.com/zerothread?id=1136026
https://honda-tech.com/zerothread?id=1117870
Old Mar 28, 2005 | 10:37 AM
Default Re: INNER TIE ROD HELLLP!!! (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">read thru these two threads. they address different problems, but the procedures are the same to separate the inner tie rod, and help seperating the outer tie rod.
https://honda-tech.com/zerothread?id=1117870</TD></TR></TABLE>
awesome...thanks tyson
Old Mar 28, 2005 | 11:35 AM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1117870</TD></TR></TABLE>
This is the info I was refering to in your EG forum thread....
Old Apr 2, 2005 | 07:10 PM
b16bluef's Avatar
Default Re: INNER TIE ROD HELLLP!!! (94eg!)
yea i have done it it is real easy just take the outter tierod end off and then the boot off and therer is a washer with flaps bend tehm out and then brake the nut loose and ur are done u have to have a alignment when u r done
Old Apr 2, 2005 | 09:53 PM
suspendedHatch's Avatar
Default Re: INNER TIE ROD HELLLP!!! (b16bluef)
So it's all easy to access from underneath the car? Or do you have to take out the splash guards inside the fender?
Old Apr 3, 2005 | 09:26 AM
fireant's Avatar
Default Re: INNER TIE ROD HELLLP!!! (shaundrake)
You can get the inner & outer tie rods and boots done with just removing the wheels only on most cars. You'll want to turn the steering wheel to get the tie rods to protrude outward toward the end you are working on.
RootMode
Feb 16, 2019 04:52 PM
skipbudlong
31
May 6, 2010 10:21 AM
project-boosteD
Sep 14, 2008 09:26 AM
rasinhell
May 3, 2005 09:23 PM
