Problem with my LF ABS sensor :(
Sorry i did not Mean my Left Front wheel ... I ment to say my LEFT REAR sensor!!!
Anyways....
Well for a long time my ABS light has been on. I pulled the code and the code was for my left ABS sensor.... But for the past 2 months the light went away and my ABS was working. I was like hell ya it fixed it's self
but last night it rained hard and my ABS light has came back
... I called Acura and asked how much it would cost to get a new ABS sensor and the labor... They told me almost 300 dollars ... I WAS LIKE WTF!!!!!!! i am wondering how can i change it myself... Is it just a sensor that plugs right in???? Where is it at so i can change it ??? has anyone done this before is it hard?? Or should i just let Acura fix it
Anyways....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">
Anyways....
Don't buy it from the stealership. Buy it from a local honda/acura junkyard or online junkyard website. It's very easy to identify because it is the only wire going to the wheel hub assembly. Just unplug the wire and unbolt the sensor from the wheel hub assembly and you're done. It takes me 2-3 mins max for both sides.
Anyways....
</TD></TR></TABLE>Don't buy it from the stealership. Buy it from a local honda/acura junkyard or online junkyard website. It's very easy to identify because it is the only wire going to the wheel hub assembly. Just unplug the wire and unbolt the sensor from the wheel hub assembly and you're done. It takes me 2-3 mins max for both sides.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">where is it located ?? behind the rotor???</TD></TR></TABLE>
yes it's behind the rotor. can't miss it.
will i have to take off my rotor to fix it or can i jack up the car , take the wheel off and get under it and unbolt it and replace it with a new one..
hey can someone host some pics for me .. because i can not find it .. im going to take a pic of under the car and see if someonme can point it out to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">hey can someone host some pics for me .. because i can not find it .. im going to take a pic of under the car and see if someonme can point it out to me </TD></TR></TABLE>
Dude it can't be that hard. It is the "ONLY" wire going to the wheel assembly, the "ONLY" "electrical" wire going to the wheel assembly. Don't make it harder then it needs to be.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraLs94Cam »</TD></TR><TR><TD CLASS="quote">a;right sorry .. i think i know where it is .. it is hooked up to the capiler .. a big black wire</TD></TR></TABLE>
yes
yes
