Boosted B16A1 or GSR swap?
Old Mar 26, 2005 | 11:22 AM
b20eg6hatch's Avatar
Default Boosted B16A1 or GSR swap?
I have a 89 CRX Si with basic bolt ons. We are getting ready to do a complete swap but I noticed for the amount of money I would have in the GSR motor and swap, I could do a boosted B16 swap for just a little bit more if not the same amount. Anyways just looking for everyones opinion.
Old Mar 26, 2005 | 11:39 AM
SwissChEz82's Avatar
Default Re: Boosted B16A1 or GSR swap? (crxsi89)
You could probably boost a B16 for the same price as buying a b18c swap and out perform the gsr engine by a lot.
Old Mar 26, 2005 | 11:43 AM
9hatch6's Avatar
Default Re: Boosted B16A1 or GSR swap? (SwissChEz82)
i would go b16 boost, i just like boost tho. but gsr's are worth it
Old Mar 26, 2005 | 11:45 AM
Burlyirishdude's Avatar
boosted b16a.....would eat up the gsr....In the right car/right driver....basic boltons would pull on a gsr....so boosted would def give you the advantage....but mak sure you do it legit....make sure you don't blow up the motor.
Old Mar 26, 2005 | 11:59 AM
civhatch90's Avatar
if it will be done properly boost the b16, otherwise stick to the b18
Old Mar 26, 2005 | 12:01 PM
SiR Inspired ED7's Avatar
b16 love
Old Mar 26, 2005 | 12:13 PM
PIC Performance's Avatar
From what I remember, a b18c's increased deck height won't clear the stock hood. Also, modification to the front crossmember is necessary, and the header will have very little ground clearance. I wanted to do a b18c EF a while back, and remember these few points.
Old Mar 26, 2005 | 12:18 PM
90HFCrX's Avatar
ok if you wanna just be straight up fast and don't care weather you blow your motor or not. By all means go b16a turbo. But it you wanna be quick and fast but be very reilable. get the b18c. I had the same opition as you either boost my b16a and be quick for a while then down the motors gone then i have nothing. or be a little quicker than my b16a but be reilable. I chose the b18c1. but the choice is yours. And actually Noob4life b18c1 isnt that much harder than a b16a it's about the same. Take a look ill post pics to prove it.
Old Mar 26, 2005 | 02:06 PM
Default Re: (90HFCrX)
Yeah I just saw your post, pretty cool. I didn't know that, everything I read seemed to mention those problems.
Old Mar 26, 2005 | 03:04 PM
c1v1c89h4tch's Avatar
Default Re: (Noob4life)
or you could get the b18c1 for right now and boost later
Old Mar 26, 2005 | 04:52 PM
roadhead's Avatar
Is 10-12 PSI on the b16 enough to significantly shorten the life-span if its properly tuned?
I would hope not
Old Mar 26, 2005 | 04:57 PM
Default Re: (roadhead)
yeah dude....you'll blow those rods...You gotta bring the comp down......or....stop at 8psi....MAX
Old Mar 27, 2005 | 05:05 AM
90HFCrX's Avatar
yeah man burlyirisdude is right. you try puttin 10 or 12 psi on a stock b16a i give that thing 3 months top if that. See the choice is yours when u slap a turbo on a stock motor sooner or later it will brake correct me if im wrong people. I no tuning is where it's at but it will give one day. nice thing about b16a short blocks is they can be pickup for about 600 plus shipping so it's all up to you
Old Mar 28, 2005 | 01:18 PM
Hell yeah guys, I appreciate it. I just saw pics of the gsr swap and I think that might be which way I will go just because it's a daily driver. I appreciate all the help. Who do you think would be the best shop to do it at. I live in Louisville, KY if anybody is around here. I wouldn't mind taking it somewhere close if it was a better shop. Thanks
Old Mar 28, 2005 | 02:06 PM
kurinto's Avatar
From what I have seen in the FI forum, reliable 250whp is easily attainable on a boosted b16. I'd suggest doing some research there.
Boomboy14
10
May 25, 2009 12:41 PM
rick ef9
Northeast (Sales)
Jul 20, 2007 06:33 AM
StingRay4
Feb 14, 2007 09:00 PM
civictech01
Oct 19, 2005 07:28 PM
ls-t del sol
Oct 7, 2002 12:31 AM
