Clutch Install
Old Mar 25, 2005 | 09:18 PM
jpnucrx's Avatar
Default Clutch Install
I've posted the past 2 days on whether or not to replace the clutch on a 91 si. Just wanted to know what the easiest way to do it? do i drop the tranny and go from there or pull the whole motor. also I got all the stuff to do it, the only thing is i've never done 1 before. I got the haynes manual, but it's hard to tell if if i could do it, workin low budget so don't really want to pay for install. By the way its a 91 si with stock tranny, and its a centerforce dual friction clutch. Thanks for any help
Old Mar 25, 2005 | 09:21 PM
teknohatchie91's Avatar
Default Re: Clutch Install (jpnucrx)
I'd say u pull the engine out.....its way easier to do. Less PITA to do.
l8er
Old Mar 25, 2005 | 09:59 PM
SOHCEK-Turbo's Avatar
Default Re: Clutch Install (teknohatchie91)
Your going to have to pull the engine much easier.
Old Mar 25, 2005 | 10:02 PM
hebelect's Avatar
Default Re: Clutch Install (EK-TSOHCV-TechRider)
futch that... drop the tranny it's much easier
Old Mar 25, 2005 | 11:58 PM
31flavorscivic's Avatar
Default Re: Clutch Install (hebelect)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hebelect &raquo;</TD></TR><TR><TD CLASS="quote">futch that... drop the tranny it's much easier</TD></TR></TABLE>
After having recently done both in less than a week, I am going to have to say that dropping the tranny out is MUCH easier than lifting the engine. From the looks of it, I believe the car was designed so that the tranny could be dropped. I don't know how accessible the clutch is from the underside of the car however.
Old Mar 26, 2005 | 12:41 AM
EL Vap133's Avatar
It takes more muscle, but less work in the longrun.
Old Mar 26, 2005 | 01:01 AM
Malgerus's Avatar
Default Re: Clutch Install (EL Vap133)
What, it's a D series???? Doing a tranny is so much easier for you than for us B series guys. Try fitting the damn B16 tranny in place. D16 tranny leaves so much room to work, just drop it and don't bother pulling the engine, seriously.
Old Apr 4, 2005 | 04:57 PM
herbalist's Avatar
Default Re: Clutch Install (Mr. S)
im about to install a new clutch on my ls would it be easier for me to drop the tranny out too? instead of pullin out the motor
Old Apr 17, 2005 | 06:22 AM
herbalist's Avatar
Default Re: Clutch Install (herbalist)
well no one has replied to this thread but i finished my clutch installation, i decided to just jack up my car and drop out the transmission which seemed relatively easy, it took about 4 days to finish the install because of lack of help and having a rusted car. Overall it went well
Old Apr 17, 2005 | 06:39 AM
90LSpimpin's Avatar
4 days, thats weak
The first time I did it it took me i think more than 2 weeks. No help at all cus everyone had left for school just b4 we got to put the tranny back up. In the process of gettin the tranny back in there, i had damaged the splines on the clutch disk, so i spent many days struggling wondering why the damn thing wasnt goin into place, till one day i decided to pull everything back off. Ended up spendin a few hours filing down the damages that i had made. Got it back up there, been fine ever since. I've done it a bunch of times since then on mine and friends cars. Alone usually takes me btwn 6-10 hours depending on which part wants to cause problems. All in all for DIY.
On the LS clutch change, drop the front crossmember. Makes life a hell of a lot easier. Just did this on my friends DA and it was cake.
Old Apr 17, 2005 | 07:05 AM
CRseXy's Avatar
Default Re: Clutch Install (89SiPimpin)
I did a clutch job. I droped the motor from the bottom. did it in a weekend with my brothers help. all we used was a craftsmen tool set. Torque wrence. and a Impact and air ratchet. I used a low profile race jack, and jack stands. its actualy VERY quite easy to drop the motor out of the bottom. Its VERY easy, It looks intimdating. but the hardest thing to do is remove the axles, everything after that is cake.
Old Apr 17, 2005 | 07:10 AM
herbalist's Avatar
Default Re: Clutch Install (pogiTSI)
yeah i didnt have an air gun which made it more difficult the process will go by MUCH easier if you have air tools
Old Apr 17, 2005 | 07:34 AM
88cerx's Avatar
i droped my ls tranny and it was ****. took about 3 1/2 hours in and out had to swap trannys cuz of a hole in the casing . went good though if any more q's let me know
dcturbols
Honda S2000
May 6, 2007 06:18 PM
rocco
35
May 10, 2004 12:45 PM
team2n1hatch
Dec 2, 2003 09:24 PM
invboost
Nov 11, 2003 06:59 PM
94si94cx
Oct 1, 2003 10:15 AM
