JDM B16 Hard Start Up
why is my engine hard to start everything i hooked up except the water temp sensor and when its warm it runs fine vtec hits good and everything but i dont understand why it takes like 7 trys to get it started????? any suggestions
From: hittin corners so hard you can taste my rims..
by-passing FPR? (fuel pressure regulator)
if you had a fuel pressure gauge mounted on the fuel filter, you would be able to see the pressure drop just after key on, engine off... when the pump primes.
if it bleeds off, you won't have enough fuel to start the car.
look for a B&M fuel pressure gauge.
you basicly replaced the banjo fitting with one thats tapped so you can add a gauge.
look in the sponcer market place here on HT.. they're everywhere.
