SDEED GUAGE PLZ HELP!!!!!!
Old Mar 25, 2005 | 12:37 AM
b18_racer805's Avatar
Default SDEED GUAGE PLZ HELP!!!!!!
i was driving and my speed guage was working just fine then all of a sudden it went crazy it just stopped working. and its throwing a code. what would the problem be. i checked the speed senor and it was fine would it be a fuse or something like that. plz help!!!!!!!
Old Mar 25, 2005 | 01:08 AM
Andres-eh2's Avatar
pull out the harness at the speed sensor and clean it or maybe just push it back in
Old Mar 25, 2005 | 02:45 AM
Bond's Avatar
Default Re: (Andres-eh2)
If it stopped working all to gether the the coil on the back of the gauge could be off. First clean out the speed sensor and then check the guage. There is no fuse to the speedo or speed sonsor, so that isn't it.
Old Mar 25, 2005 | 03:28 AM
LSegHatchy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">If it stopped working all to gether the the coil on the back of the gauge could be off. First clean out the speed sensor and then check the guage. There is no fuse to the speedo or speed sonsor, so that isn't it.</TD></TR></TABLE>
what he said
good luck
Old Mar 25, 2005 | 07:31 AM
do speed sensors ever go bad
Old Mar 25, 2005 | 09:28 AM
O3DigitalBath's Avatar
^yes i've seen a few go bad before, but its not all that common
Old Mar 25, 2005 | 11:12 AM
ill chec the connections on the back og the cluster and the tranny.it wouldnt be anything else would it.
Old Mar 25, 2005 | 12:14 PM
Bond's Avatar
Default Re: (b18_racer805)
Has it stopped working at all? If so then check and clean your connections at the speed sensor and back of cluster. If still nothing, then pull the guage and sheck the coil. If the coil is good and attached, then try replacing the speed sensor. For a speed sensor to go is pretty uncommon, but I have seen it before. Check all of these in that order and get back to us after you do it .
Old Mar 25, 2005 | 06:11 PM
checked all that out and still not working it looks like the connector to the speed sensor is corodid.so i think its the plug to the speed sensor
Old Mar 25, 2005 | 07:06 PM
nota-ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_racer805 &raquo;</TD></TR><TR><TD CLASS="quote">do speed sensors ever go bad</TD></TR></TABLE>
Yes! If you have to replace your VSS try to do it yourself. Costs me $400+ to have them replace mine, and my **** still doesn't work. If it ever quits raining I'm going to pull my cluster over spring break to see if everything is in the cluster good and tight. What can you clean the VSS with? Would TB cleaner work, or would that jack it up?
Old Mar 25, 2005 | 07:18 PM
I DONT think it is the speed sensor it. i think its the connector to teh speed sensor
Old Mar 25, 2005 | 08:24 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18_racer805 &raquo;</TD></TR><TR><TD CLASS="quote">I DONT think it is the speed sensor it. i think its the connector to teh speed sensor</TD></TR></TABLE>
Go to the junkyard and cut one off and wire it back up. Should take care of your problem.
Old Mar 25, 2005 | 08:26 PM
yea i am doing that tomarrow and ill let you guys know whats up with it
Old Mar 26, 2005 | 06:56 PM
yup that was the problem its all fine now
Old Mar 26, 2005 | 07:00 PM
Bond's Avatar
Good to hear .
ONEhaque
Nov 4, 2008 06:31 PM
EgDude
Jun 11, 2008 02:30 PM
boostedteg15
Mar 8, 2006 10:19 AM
turismo128
Sep 27, 2005 03:22 PM
jshelley45
Dec 18, 2004 11:30 PM
