VTEC wired, but no VTEC
Old Mar 24, 2005 | 10:42 PM
Ch3mik's Avatar
Default VTEC wired, but no VTEC
I wired up the vtec solenoid and the vtec oil pressure on my crx. I take it for a spin, I have no check engine light. I get on it. no vtec, I cruise it slowly, go to 5000rpms. no vtec. heres some pics of what i did. I wired up the A8 and B5 . I have plenty of oil in the motor. anyone have any ideas?
Old Mar 24, 2005 | 10:47 PM
.john.'s Avatar
Default Re: VTEC wired, but no VTEC (Ch3mik)
is your speedometer working? if not this will cause it.
Old Mar 24, 2005 | 10:51 PM
88ED8's Avatar
Is the oil pressure grounded? Are you using a vtec ecu? Whats the set up????
Old Mar 24, 2005 | 10:52 PM
88ED8's Avatar
Check for CEL/codes, reset the ecu...
Old Mar 24, 2005 | 10:55 PM
Ch3mik's Avatar
Default Re: VTEC wired, but no VTEC (sportcarae)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sportcarae &raquo;</TD></TR><TR><TD CLASS="quote">is your speedometer working? if not this will cause it.</TD></TR></TABLE>
as a matter of fact its not workin. haha. the idiot I got this shell from gave it to me with a chewed up speedometer cable. he got me a new one and i plugged it up but It dont work. do I need a new cluster? damn. this sucks
Old Mar 24, 2005 | 11:03 PM
.john.'s Avatar
vtec needs only, rpm, oil pressure, speed, water temp. check these.
Old Mar 24, 2005 | 11:05 PM
Ch3mik's Avatar
thanks a lot man. I got no speedo so I guess thats it. anyone have a 90-91 si cluster? will this drop into the 90 HF?
Old Mar 24, 2005 | 11:09 PM
.john.'s Avatar
if you changed the cable but the speedo still doesnt work, one of the ends of the cable isn't plugged in right. the gauge cluster is mechanical and almost never goes bad.
Old Mar 25, 2005 | 12:28 PM
Ch3mik's Avatar
well. the tranny end just goes in the hole on mine. i thought it had like a rubber boot or somethin. ill get a pic or just go to the dealership to see if they have one in stock by any rare chance
Old Mar 26, 2005 | 11:18 AM
strictlyimport's Avatar
you will have to buy the whole cable. they just don't sell the boot. mine is missing the boot also and i tried to get just that, but they said that i had to buy the whole cable......its not that expensive though.
Old Mar 26, 2005 | 11:47 AM
Burlyirishdude's Avatar
Default Re: VTEC wired, but no VTEC (strictlyimport)
make sure the clip is in the right place. CHECK ALL GROUNDS....no CEL doesn't mean no ecu codes....go and check it out.....
Old Mar 26, 2005 | 12:58 PM
doublethink's Avatar
yea theres a minimum speed you need to be traveling at for the vtec to come on.
what engine swap, b16a?
Old Mar 27, 2005 | 10:02 PM
Ch3mik's Avatar
Default Re: VTEC wired, but no VTEC (doublethink)
UPDATE!
I got a new speedometer cable ($40), installed it, ran it, no CEL, MAD VTEC. now I got a CODE 6, coolant temp sensor. If the CEL light comes on, I have no vtec. is this sensor the one below the dist closer to the front of the head (w/ 2 wires comin out)? If I turn off the car then start it up again, I got vtec. can someone comfirm with me cuz im 99.9% sure this is the case.
Old Mar 27, 2005 | 11:49 PM
WhiteDSM520's Avatar
When I had a code six it reffered to the single prong under the dizzy. It's kinda hard to see. but look and you'll find it. My wires had oil built up on them from my leaky d16 and it killed the wire. So I just fixed that and I had no code and vtec again. Maybe yours just popped off.
Old Mar 28, 2005 | 10:49 PM
Ch3mik's Avatar
Default Re: VTEC wired, but no VTEC (WhiteDSM520)
hm. ill look into that. thanks
Old Mar 28, 2005 | 10:56 PM
88ED8's Avatar
Just looked at pics of your car
Old Mar 29, 2005 | 03:18 PM
Ch3mik's Avatar
Default Re: VTEC wired, but no VTEC ('89ED8)
thanks
Old Mar 29, 2005 | 03:59 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteDSM520 &raquo;</TD></TR><TR><TD CLASS="quote">When I had a code six it reffered to the single prong under the dizzy. </TD></TR></TABLE>
I dont think that causes a code. I believe that sender is for the temp gauge on the cluster (if it unplugged/broken, the gauge wont register). The 2 wire connector is the one you will want to look at.
Old Mar 29, 2005 | 05:24 PM
91dxhatchswaped's Avatar
Default Re: VTEC wired, but no VTEC (fourthgenhatchB17)
did you ground the right wire (green ) on the oil pressure switch. If you got them confused you fried the switch or the ECU
Old Mar 30, 2005 | 02:25 AM
it does. i've had the wire break on me twice.
Old Mar 30, 2005 | 11:56 PM
Ch3mik's Avatar
its grounded fine. I didnt mess with any of that . the motor came out of my old black crx and went into the white one. the only wiring done was the 2 wires into the ecu. whats wierd on my situation is that the CEL will come on , then if i shut it off then back on it doesnt come back and the car drives REALLY good. lol. im just doin that if the CEL comes on.
chinoslines
Jun 30, 2010 08:47 AM
breanna*
12
Aug 2, 2006 09:29 AM
b16mike
May 13, 2005 09:51 PM
acdracing
Dec 13, 2004 06:13 PM
vspec12
Nov 5, 2001 05:25 AM
