Simple Ign. Timing Question
I have a mod. 89 honda crx hf with a gsr head witha b16a2 short block. I have the car runnin now and was wondering for the ignition timing. Do I set it at 15 degrees B/c I'm using a Chipped P-72 (obd-1) ecu on my car? Also note that I already did the obd-0 to obd-1 conversion already and I brought the car to a local shop to do check my timing. They check it and set it at 22 Degrees B/c I burn out and crack two of my valves. (which suxc) So once again do I set it at 15 degrees? (the number came from Acura)
<Thanks for reading>
Is that initial timing or total timing? My car is running 16 degrees initial timing and 31 degrees at 3k. 21 degrees base timing seems a little high to me. Especially on a car with a chipped ecu thats adding a couple more degrees of total advance. As long as there is no detonation you should be fine. But typically a car will run better on the top end with timing retarded a little bit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sack Master »</TD></TR><TR><TD CLASS="quote">Is that initial timing or total timing? My car is running 16 degrees initial timing and 31 degrees at 3k. 21 degrees base timing seems a little high to me. Especially on a car with a chipped ecu thats adding a couple more degrees of total advance. As long as there is no detonation you should be fine. But typically a car will run better on the top end with timing retarded a little bit.</TD></TR></TABLE>
I need to know initial timing and total timing. B/c my total timing is 22 degrees and my chip has a on/off switch.
Thanks
Thanks
