DIY 99-00 climate control
Old Mar 23, 2005 | 05:52 AM
kleanlscivic's Avatar
Default DIY 99-00 climate control
hey everyone i have been searching for about 20 min now archived and recent and i cannot find anything tell me how to do a DIY amber lights for a 99-00 civic climate control like which bulds to paint and all that i know i have seen them before but i cant find them now. thanks for the help everyone!
Old Mar 23, 2005 | 06:39 AM
SkRiBLaH's Avatar
Default Re: DIY 99-00 climate control (kleanlscivic)
you just take out the light bulbs and paint them red!!!!!!!
its not rocket science
Old Mar 23, 2005 | 11:28 AM
Default Re: DIY 99-00 climate control (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">you just take out the light bulbs and paint them red!!!!!!!
its not rocket science</TD></TR></TABLE>
no ****, i am saying how do i get the bulbs out without breaking any of the panels?
Old Mar 23, 2005 | 12:04 PM
bump
Old Mar 23, 2005 | 01:32 PM
wrEcKed_LX's Avatar
It is actually very simple. I have had my cluster out at least 7 or 8 times.
Step 1...Unscrew the top two bolts of the black gauge surround.
Step 2...Gently tug on the black gauge surround and remove it, you will see 4 screws around the actualy cluster; two that are straight in at the bottom, and two that are near the top around the same location of the gauge surrounds bolts.
Step 3...After removing the screws, your cluster should be able to be angled toward you(the top should be angled toward you) and then you simply unplug the harnesses.
Step 4...Look at the back of the gauge cluster and you will see several bigger size brown/black/green plugs. Those are the light bulb housings. If you unscrew them, you simply twist and pull them out, then you just swap out the bulbs. I bought my bulbs from advance for like $7 total. Or then you could paint the stock ones if desired. Not sure on the size of the bulbs off the top of my head though...
I hope this helps.. If you want more information just let me know. Also, i can get pictures if you want me to, but it is very simple. I dont even take anything off of the gauge cluster except the little plugs. After you get them done, try plugging one of the cluster plugs in and turn your lights on to see if it works. I think its one of the smaller ones...?
Old Mar 23, 2005 | 01:49 PM
green-'s Avatar
Default Re: DIY 99-00 climate control (spoon_ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon_ferio &raquo;</TD></TR><TR><TD CLASS="quote">It is actually very simple. I have had my cluster out at least 7 or 8 times. </TD></TR></TABLE>
He's talking about the climate control, not the gauge cluster.
https://honda-tech.com/zero...age=1
That might be what your looking for.
Old Mar 28, 2005 | 08:21 AM
wrEcKed_LX's Avatar
Default Re: DIY 99-00 climate control (green00EX)
Sorry about that one guys... I have never even figured out how to get my climate control out or access the bulbs.
Old Mar 29, 2005 | 02:15 PM
its all good man try that right up he just put it is really good. i am going to try it tonight if i can ever find the paint
green-
248
Feb 18, 2018 09:56 AM
amej8
Jan 14, 2007 12:29 PM
blue92da
16
Feb 10, 2006 04:55 PM
HBP.EH2
Mar 15, 2005 07:54 PM
tibbor
Mar 21, 2004 09:12 PM
