02 sensor replacement D16Y8
Old Mar 23, 2005 | 05:39 AM
AutoXer's Avatar
Default 02 sensor replacement D16Y8
Well, it's getting to the point where I need to replace my 02 sensors, and the prices (from http://www.slhondaparts.com) are f'n rediculous:
36531-P2P-A01 SENSOR, OXYGEN $192.27
36532-P2P-A01 SENSOR, RR. OXYGEN $192.27
I know I shouldn't run Bosch or generic 02; so does anyone know who is the OEM supplier, and where I can get these cheaper?
Old Mar 23, 2005 | 05:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: 02 sensor replacement D16Y8 (EX_AutoXer)
i have had a http://www.oxygensensors.com in mine for the last 2 years no issues. li,ke 80 shipped if i remember correctly. plug and play.
Old Mar 23, 2005 | 06:24 AM
HitEm'Up's Avatar
Default Re: 02 sensor replacement D16Y8 (boostedcivicsir)
Old Mar 23, 2005 | 06:28 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">i have had a http://www.oxygensensors.com in mine for the last 2 years no issues. li,ke 80 shipped if i remember correctly. plug and play.</TD></TR></TABLE>
Great find, thanks
So, since the OEM are listed as Walker:
https://www.automedicsupply.co...d7058
I'm assuming the only difference between the 'OEM' and 'universal' is that I'll have to splice the universal in?
Is there some type of wire color convention for the sensors, so that I will know which wires to splice together?
Old Mar 23, 2005 | 07:14 AM
snatch's Avatar
Try http://www.sparkplugs.com, they have them for about $40-$45 a pop.
I think when you get them, they have instructions that tell you which wire is for ground, power, heater, etc.
edit: You're correct about the universal, the OEM has the plug attached, and the universal you will have to solder the wires in.
Old Mar 23, 2005 | 07:52 AM
Happyman's Avatar
Default Re: 02 sensor replacement D16Y8 (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">Try http://www.sparkplugs.com, they have them for about $40-$45 a pop.
edit: You're correct about the universal, the OEM has the plug attached, and the universal you will have to solder the wires in.</TD></TR></TABLE>
No....I bought a universal from oxygensensors.com once and it plugged right in....
Old Mar 23, 2005 | 08:21 AM
civic-4-ges's Avatar
OEM Oxygen sensor are high priced, is that for the primary sensor or the post-cat sensor?
Old Mar 23, 2005 | 08:23 AM
Mr. Badwrench
Default Re: 02 sensor replacement D16Y8 (civic-4-ges)
i believe they have both. my car is obd1 so i have no post cat sensor.
Old Mar 23, 2005 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">i believe they have both. my car is obd1 so i have no post cat sensor.</TD></TR></TABLE>
OK, maybe I missed typed. The prices listed above....are they for the primary or secondary catalytic convertor?? Secondary is generally a little more expensive, however identical to the primary, except for the length of wire and the rubber grommet to go into the interior of the car
Old Mar 23, 2005 | 09:00 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">
No....I bought a universal from oxygensensors.com once and it plugged right in....</TD></TR></TABLE>
Really? The pics and diagrams show it as bare wire, and show shrink wrap as included...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">OEM Oxygen sensor are high priced, is that for the primary sensor or the post-cat sensor?
The OEM price I listed was for both. The one listed as RR is the rear, but they're the same price.
From oxygensensors.com:
Primary:
OEM 4 Walker $219.90 Today 250-24398 VIEW Replaces #'s
Universal 4 Walker $51.90 Today 250-24400 VIEW Replaces #'s
Secondary:
OEM 4 Walker $149.99 Today 250-24105 VIEW Replaces #'s
OEM 4 Denso $194.99 Tomorrow 234-4098 VIEW Replaces #'s
Universal 4 Walker $59.90 Today 250-24200 VIEW Replaces #'s
Sparkplugs.com only lists the rear. Is there actually a difference between them? They are listed as different part numbers, but sparkplugs only has one listing.
Old Mar 23, 2005 | 09:46 AM
Happyman's Avatar
Iono I just bought one off ebay though for 60 shipped brand new not sure the brand but its got a clip on it for my car.
Old Mar 23, 2005 | 10:38 AM
AutoXer's Avatar
Default Re: 02 sensor replacement D16Y8 (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">Iono I just bought one off ebay though for 60 shipped brand new not sure the brand but its got a clip on it for my car.</TD></TR></TABLE>
Yeah, I checked there, and they have a walker 02 with a plug for about that price. But there's no listing for if it's front or back, or a reference part number.
So that brings me back to: is there a difference between the front and rear sensors?
Old Mar 23, 2005 | 10:41 AM
IHateJDM's Avatar
Try cleaning it with carb cleaner before replacing it. Worked damn well for me.
Old Mar 23, 2005 | 10:42 AM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
No, no different other than wire length and the rubber gromet
Old Mar 23, 2005 | 11:05 AM
snatch's Avatar
I looked on the website and ones listed as OEM have a plug in the picture. Ones listed as Universal do not have a plug, just bare wire with some shrink tubing, like EX_AutoXer said.
Good thing there's no difference. $89 + tax for 2 of them from http://www.sparkplugs.com then.
EX_AutoXer - how did you know when it was time to replace your O2 sensors? How many miles on your car? Just debating when it's time for mine to be done.
Old Mar 23, 2005 | 11:12 AM
Happyman's Avatar
Well I bought the one for 60$ from oxygensensors.com and it plugged in so i dunno. I remember buying the cheapest.
Old Mar 23, 2005 | 11:37 AM
flood's Avatar
Old Mar 23, 2005 | 11:38 AM
AutoXer's Avatar
EX_AutoXer - how did you know when it was time to replace your O2 sensors? How many miles on your car? Just debating when it's time for mine to be done. </TD></TR></TABLE>
I've got 110K on the clock. They're design life is around 60K if I remember correctly, so by milage alone, I'd say it's time. I've been putting it off because of the expense, but my gas milage is pretty poor lately; since it's the only regular maintenance I haven't done, I'm going to see if it helps.
It's basically a cost benifit thing; I was pretty sure my milage was dropping from the 02, but it was expensive, so I'd waste a bit more gas. Now that it's getting pricey, it's time to start looking into dishing out the cash for the 02 to get my milage back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman &raquo;</TD></TR><TR><TD CLASS="quote">Well I bought the one for 60$ from oxygensensors.com and it plugged in so i dunno. I remember buying the cheapest.</TD></TR></TABLE>
Maybe I'll get lucky then.
No, no different other than wire length and the rubber gromet </TD></TR></TABLE>
But the wire / gromet will work in both locations, correct?
Old Mar 23, 2005 | 05:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">But the wire / gromet will work in both locations, correct?</TD></TR></TABLE>
The plug end will, the grommet will just sit there at your primary o2. Just cut it off,orleave it hanging.
Hatch_Back_97
Aug 29, 2006 10:45 AM
seeeya04
Nov 11, 2005 03:07 PM
imadigitalgod
Feb 19, 2005 10:12 AM
yellowwinter
Feb 13, 2005 11:21 PM
Nameless RB26
Nov 12, 2003 12:05 PM
