oil return line?
Old Mar 22, 2005 | 07:17 PM
Boring's Avatar
Default oil return line?
My oil return line to the oil pan is being knocked off do to the engine torquing. I bought a new oil pan but need it welded at a lower location on the oil pan to the down pipe doesnt knock it off anymore. does anyone know if mineki (SP?) would do this?
thanks
Old Mar 22, 2005 | 07:37 PM
Brandon Clifton's Avatar
Default Re: oil return line? (Boring)
It usually depends on the shop. Most are franchised and it just depends on how busy they are, how much of a car guy the shop foreman is, and what kind of mood he's in.
You could also use a bulkhead fitting http://www.buyfittingsonline.c...7.htm
I know $33.00 seems expensive, but any exhaust shop is going to charge at least $20.00 just to let you thru the door, and this thing can be replaced.
All you need to do is drill (or use a holesaw to cut) a 1" hole in the oil pan, slip a neoprene washer over the fitting, put it through the oil pan, add another washer, and tighten the nut. Then your AN line will screw right on.
Old Mar 22, 2005 | 08:17 PM
Boring's Avatar
Default Re: oil return line? (Brandon Clifton)
hmm interesting thanks for the info
Old Mar 23, 2005 | 09:17 AM
dfoxengr's Avatar
i doubt they would. maybe your first time wasnt welded on good enough
Sordz
Mar 14, 2010 06:39 PM
Boosted_B_Series
Jan 2, 2007 09:42 PM
B18c1turboedEK
Feb 21, 2005 10:32 AM
Evil EG
Apr 3, 2002 07:30 PM
