Oil return question, need advice
Old Mar 14, 2010 | 06:27 PM
Sordz's Avatar
Default Oil return question, need advice
NOTE** The picture is NOT my car or engine only used for example**
Would this be alright for a oil return being the line goes down and below the actual tap in the oil pan or does it need to be a constant angle going into the pan? On my car I cant get a good angle because of subframe so I either have a tight bend and restrics the oil retun hose size but has decent angle or I run about 1 foot of line simular to this that would go around my intercooler pipe.
Old Mar 14, 2010 | 06:39 PM
boostedEF91's Avatar
Default Re: Oil return question, need advice
no not a good oil return line.. As you see the oil has to flow up a hill into the oil pan. thats not flowing very well now is it. now if you would put a 90 Degree AN fitting off the turbo then over to the pan you would be fine. even a 45degree angle would work in that picture.
EG6 Love
Sep 6, 2015 02:30 PM
solo2fresh
Mar 2, 2011 04:09 PM
bb_one
Jul 17, 2006 10:49 PM
shadow103rd
May 12, 2004 11:55 AM
torr
Apr 14, 2004 07:48 AM
