hondata, iac duty cycle
Old Jan 25, 2002 | 12:06 AM
Brian_92GSR's Avatar
New User
Default hondata, iac duty cycle
Can anyone tell me exactly what this setting does? I'm having a problem with my idle - when I take the car out of gear the RPM will drop way too low (around or maybe lower than 500) then it will correct itself after a second and idle fine. I think it tends to happen mainly when the car is cold.
Old Jan 25, 2002 | 06:54 AM
Mike K's Avatar
Default Re: hondata, iac duty cycle (Brian_92GSR)
Mine does this too.. I wouldn't worry about it..
Mine doesn't surge.
It's just after a hard run when I put the clutch in.. it drops to like 400-500 then comes right back up to 1000.
Old Jan 25, 2002 | 07:35 AM
New User
Default Re: hondata, iac duty cycle (Mike K)
That's exactly what mine does. I'm not really worried about it, I just want it fixed.
Old Jan 25, 2002 | 11:30 AM
GSR_Hacker's Avatar
New User
Mine does that when cold. I have a P-28 ECU and it only did that when I installed that... I do not have my Hondata as of yet... but I guess it wont go away when I install the hondata huh? Oh well.. the car hasn't died yet because of it, and I never have to give it gas, so I'll take it as it is...
Old Feb 4, 2002 | 01:00 PM
XES's Avatar
XES
Default Re: hondata, iac duty cycle (GSR_Hacker)
The best way to fix the idle (before messing with the duty cycle) is to play around with the low speed fuel map (if you have 4B and an emulator, etc.). The stock tuned platforms made by Hondata do a pretty good job in this department. If the low speed maps don't help (which they should), play with the duty cycle. If you play with the duty cycle first, the problem may not be fixed.
The key in in the low maps.
XES
mr.4b w/ 720's
[Modified by XES, 3:01 PM 2/4/2002]
BDogggUT34
Jun 8, 2007 08:38 AM
Kwuaymaikrup
Sep 16, 2004 02:20 AM
Boosted2K
Aug 28, 2004 07:20 AM
HX_Guy
Jan 11, 2002 10:41 AM
