Post your Idle RPM. Have a question?
First off, post up what your rpms are at warmed up idle. From datalogging Hondata S200, mine sits around 950rpms. I'm assuming tuner set it this way, is that normal for everyone on a boosted car or is it too high? Second, only on cold startup, the idle goes from around 1200-1500 surging for about 3min, then everything is fine, it goes back to steady 900-950 idle. No leaks, and everything was perfect before turbo install. Just wanting to know if this is in the Hondata software, and what everyone elses does. Thanks
Modified by BDogggUT34 at 9:49 AM 6/8/2007
Mine idle the same as your when it's normal temp. Only thing different is that my doesn't surge. I doubt hondata have anything to do with it. Even though I could be wrong since I never run hondata before.
