tools for making header oval for flange
some guys make a mold and use it in a press. make the top half and the bottom half. put the bottom piece in, put the tubing in, then then top piece. then press the top to the bottom
Thanks guys . I use all those . Mild steel is cool but when doing SS it's a different story . The tube gets all jacked up . Man that's alot of money too .
I just took a flange cut off one of the ports and then cut the flange in half. Took a little extra material off so you can clamp down a little more (needed due to material springing back). Welded the 2 pieces of flange in a dedicated vise and just clamp away. Works great.
dosent bmc . advertiser here , sell a flange that has a circle on one side and the oval port on the other .. so no squishing is needed .. fits right in .. looks very good and fairly inexpensive for the quality
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">I just took a flange cut off one of the ports and then cut the flange in half. Took a little extra material off so you can clamp down a little more (needed due to material springing back). Welded the 2 pieces of flange in a dedicated vise and just clamp away. Works great.</TD></TR></TABLE>
Man , that worked wonders .. Thanks . Cheap and great , can't beat that . Thanks
Guest
Posts: n/a
man you guys are to high tech(ha ha) for me .I just lay the tube down on the bench and hit the end of it with a rubber hammer.And it fits perfect every time.Besides you have to knock it out in the flange and tack it anyway.
danielm3
Welding / Fabrication
Jan 31, 2006 08:35 AM
