tools for making header oval for flange
Old Mar 22, 2005 | 10:02 AM
lovitalracer's Avatar
Default tools for making header oval for flange
What does everybody here use to make the tubing oval to fit a header flange ?
Besides a vice .
Old Mar 22, 2005 | 01:41 PM
98AccordEX's Avatar
Default Re: tools for making header oval for flange (lovitalracer)
some guys make a mold and use it in a press. make the top half and the bottom half. put the bottom piece in, put the tubing in, then then top piece. then press the top to the bottom
Old Mar 23, 2005 | 05:59 AM
spiceisler's Avatar
Default Re: tools for making header oval for flange (98AccordEX)
I use a 3lb sledge. Works like a charm on sch40.
Old Mar 23, 2005 | 07:30 AM
Ekasey's Avatar
Vice with special jaw setup, also a whole lot of hammer forming to get it spot on.
Old Mar 23, 2005 | 09:02 AM
Default Re: tools for making header oval for flange (eLusive ek4)
Thanks guys . I use all those . Mild steel is cool but when doing SS it's a different story . The tube gets all jacked up . Man that's alot of money too .
Old Mar 23, 2005 | 09:29 AM
Ekasey's Avatar
Try using a brass hammer or a plastic type rubber
Old Mar 23, 2005 | 09:38 PM
SMSP's Avatar
I just took a flange cut off one of the ports and then cut the flange in half. Took a little extra material off so you can clamp down a little more (needed due to material springing back). Welded the 2 pieces of flange in a dedicated vise and just clamp away. Works great.
Old Mar 23, 2005 | 11:01 PM
turbo gli's Avatar
Default Re: tools for making header oval for flange (SMSP)
dosent bmc . advertiser here , sell a flange that has a circle on one side and the oval port on the other .. so no squishing is needed .. fits right in .. looks very good and fairly inexpensive for the quality
Old Mar 24, 2005 | 08:23 AM
Eddiebx's Avatar
yes he does, they look really nice
Old Mar 25, 2005 | 08:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">I just took a flange cut off one of the ports and then cut the flange in half. Took a little extra material off so you can clamp down a little more (needed due to material springing back). Welded the 2 pieces of flange in a dedicated vise and just clamp away. Works great.</TD></TR></TABLE>
Man , that worked wonders .. Thanks . Cheap and great , can't beat that . Thanks
Old Mar 25, 2005 | 10:59 AM
fastcivicboy's Avatar
Default Re: tools for making header oval for flange (turbo gli)
pretty smart man. Thanks for the advice and helpful tip. -Nick
Old Mar 25, 2005 | 07:10 PM
RMF
Guest
Posts: n/a
Default Re: tools for making header oval for flange (fastcivicboy)
man you guys are to high tech(ha ha) for me .I just lay the tube down on the bench and hit the end of it with a rubber hammer.And it fits perfect every time.Besides you have to knock it out in the flange and tack it anyway.
end005
Welding / Fabrication
Mar 30, 2012 08:34 PM
vtec_lude
Jul 2, 2007 02:23 PM
danielm3
Jan 31, 2006 08:35 AM
luv2drivecrx
Oct 23, 2005 08:03 AM
nerdsports
Jun 15, 2005 09:33 AM
