What will I run with this setup? (Turbo Ls)
I will be bringing it to the track shortly, cnsidering a get a decent launch, what kinda times should i be able to pl with this setup?
95' Integra LS. Drag 3 kit, clutchmasers stage 3 clutch. 7-8 lbs of boost on stock injectors. I will be running open downpipe also.
Smarter than you
whaaaat turbo LS's have u seen..
IF you can drive Great.. turbo LS 9psi and open downpipe will run 12's on slicks.. On streets your looking at 13.5's if u can drive.. Considering its your first time, shoot for a low 14..
Ok, what about me then. Same thing. Well not really, not a Drag3 kit, but similiar turbo setup. Only in Si hatchback. Running a Gsr tranny. My sig has the N/A times on street tires.....
quikB18B
Apr 7, 2004 03:43 PM
