What will I run with this setup? (Turbo Ls)
I will be bringing it to the track shortly, cnsidering a get a decent launch, what kinda times should i be able to pl with this setup?
95' Integra LS. Drag 3 kit, clutchmasers stage 3 clutch. 7-8 lbs of boost on stock injectors. I will be running open downpipe also.
Banned
Re: What will I run with this setup? (Turbo_Teg)
If it's your first time, you'll probably hit low low 14's, if your really good at driving, you'll hit high 13's.
Smarter than you
whaaaat turbo LS's have u seen..
IF you can drive Great.. turbo LS 9psi and open downpipe will run 12's on slicks.. On streets your looking at 13.5's if u can drive.. Considering its your first time, shoot for a low 14..
Will you make something up for me please?
Re: What will I run with this setup? (DIRep972)
Ok, what about me then. Same thing. Well not really, not a Drag3 kit, but similiar turbo setup. Only in Si hatchback. Running a Gsr tranny. My sig has the N/A times on street tires.....
quikB18B
04-07-2004 03:43 PM
