How much should i mill off my head?
I'm switching out blocks on my B18C1 so my head has to go to the shop.
Putting in ITR cams, and a Mugen 2-layer thin headgasket. That is said to raise compression, what, .3 points?
Im going for a high compression re-build, w/o having to upgrade fuel managment at the moment. How much can i mill off the head to get safely into the mid-high 11's in compression?
I just dont want my pistons slapping my valves.
I would just resurface the head if your already getting a thinner gasket. Get some P30s in there and with the gasket you should be around 11.5 to 12s
Try this Calculator
http://www.c-speedracing.com/h...c.php
Try this Calculator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">I would just resurface the head if your already getting a thinner gasket. Get some P30s in there and with the gasket you should be around 11.5 to 12s
Try this Calculator
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
That's the thing, at the moment i do not want to do pistons. So, milling the head seems like the best choice.
Try this Calculator
EGbeater
14
Apr 19, 2004 09:04 AM
