B18C1 Smoking under high RPM?
Old Mar 21, 2005 | 12:30 PM
420aNT's Avatar
Default B18C1 Smoking under high RPM?
Ok so I have a 01 GSR motor in my 89 CRX SI. The car smokes blue under high rpm pretty bad. What can be the problem. I am running the Z10 Oil catch can and PCV valve block off. Any suggestions?
Old Mar 21, 2005 | 12:31 PM
EP3_05's Avatar
Default Re: B18C1 Smoking under high RPM? (18gTeg)
Piston rings...valve guide seals....
Blue smoke indicates oil burning. So somehow oil is entering the combustion chamber and being burnt off. Do a compression and leakdown test to check the health of the engine.
j-bird20
Jan 11, 2007 05:59 PM
tianporn
10
Jul 20, 2004 11:24 AM
roninb18
Feb 28, 2003 10:19 AM
redteg1
Sep 19, 2002 04:29 PM
