Code 5 and Rough Idle
Old Mar 21, 2005 | 12:13 PM
Pete_SI's Avatar
Default Code 5 and Rough Idle
We just swap a D16Z6 in my buddy's DX and we are having problems with the idle and throwing CEL #5 (manifold absolute pressure sensor). I know we are not having the CEL #7 but the throttle position sensor could be defective could this cause the problem? I need a little input.
Old Mar 21, 2005 | 12:44 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Code 5 and Rough Idle (Pete_SI)
make sure the tps and the map pluge are on the correct sensor. if they are, swap in a known good map.
Old Mar 21, 2005 | 12:59 PM
Pete_SI's Avatar
Default Re: Code 5 and Rough Idle (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">make sure the tps and the map pluge are on the correct sensor. if they are, swap in a known good map.</TD></TR></TABLE>
How could I check this. Just switch them and check for a CEL?
Modified by Pete_SI at 7:29 PM 3/21/2005
Old Mar 21, 2005 | 02:31 PM
Pete_SI's Avatar
I just need a little input from someone's past experience.
Old Mar 21, 2005 | 02:39 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by Pete_SI at 7:29 PM 3/21/2005</TD></TR></TABLE>
map sensor is white, green/white, and yellow/red wires
TPS is yellow/white, red/blue, and green/white wires.
Old Mar 22, 2005 | 03:12 AM
Pete_SI's Avatar
Default Re: Code 5 and Rough Idle (sleeperciv)
I checked that. Any thing else that could cause this problem.
whitelightning
Feb 8, 2006 01:15 PM
Kyle244R948
Sep 24, 2004 03:26 PM
Race Egr
Apr 5, 2004 10:32 PM
DAMCOOLDAV
Sep 12, 2003 02:05 PM
FourthGenHatch
May 19, 2003 10:51 AM
