funny idle
Old Mar 21, 2005 | 09:38 AM
1TwistedEG's Avatar
Default funny idle
well my b16 has been idling up and down here lately but will sometimes quit....but when it quits it'll ilde at like 1500..any suggestions
Old Mar 21, 2005 | 02:44 PM
1TwistedEG's Avatar
Old Mar 21, 2005 | 04:11 PM
ted's Avatar
ted
i have the same problem with my newly installed gsr in my hatch back what could it be?
Old Mar 21, 2005 | 04:42 PM
r3dh4tch's Avatar
Default Re: (ted)
Common problems with idling is the IAC (Idle Air Control Motor). It's on the back of the intake manifold and often times they are damaged when engines are taken out or shipped. I've seen this problem more than once and experienced it myself with my LS swap. Check to see if the housing where on the motor of the IAC is damaged, cracked, or if the connector is bad. If none of these things are present, trace the wires that are connected to the IAC and see if any are damaged. If you still cannot find anything, post back.
Tony
Old Mar 21, 2005 | 06:25 PM
96ls's Avatar
Default Re: (r3dh4tch)
check out the FITV on the b16 its right below the thorottle body...on the gsr, i have no clue where its at
https://honda-tech.com/zerothread?id=699787
Old Mar 21, 2005 | 07:55 PM
1TwistedEG's Avatar
we tried that 96ls and i've had the motor in the car for awhile and never had any probs. couple of months i guess...i couldnt find any vacum leaks or anything..sometimes it'll idle funny and sometimes it wont do it at all...wierd...but when it dont surge (idle up and down) it idles at like 1200.... im lost
Old Mar 21, 2005 | 08:29 PM
socki18's Avatar
Default Re: (1TwistedEG)
im experiencing the same problem as you right now.
i just did a B16A swap. my car idles and 3-3500k when cold and 2-2500 when warmed up.
ive replaced all vacuum lines, swapped in a new IAC, checked the FIT valve, put new TB gasket on, put a new intake mani gasket, checked the throttle cable tension, replaced the PCV for the hell of it, checked butterfly on TB for full closure, bled the coolant several times.
i still have the same problem after all of this.
its starting to really **** me off because i cant find the issue.
so any help to this would be great.
Old Mar 22, 2005 | 03:38 AM
96ls's Avatar
Default Re: (socki18)
have you checked the intake manny gasket?
Old Mar 22, 2005 | 09:39 AM
1TwistedEG's Avatar
its brand new....
Old Mar 28, 2005 | 08:42 PM
socki18's Avatar
well bleed your coolant first and see if that fixes it. then check the timy set screw where the throttle rotor sits. some times it needs to be turned 1 turn or so. its a 6mm allen key you use to adjust it.
Old Apr 2, 2005 | 10:46 AM
1TwistedEG's Avatar
have any pics to explain what your talkin bout?
Old Apr 2, 2005 | 02:37 PM
HULKHATCH10's Avatar
sup, i happen to have the same prob, as both of you . kinda sounds like the car angry !!..lol i have a 94 hatch dx and couple of weeks ago it started to do the same thing ....brrromm broomm ....after a couple of minutes it stops and idles around 1,000 rpm my engine is fine coolant ,check thermostat for the hell of it, all valves....iac...u name it .....nuthing.. but there was sumthing i never thought of that might be the problem..... '' i havent had a tune up'' maybe spark plugs ..wires , i dunno .i also played with the idle positioning screw found on top of the throttle body on the 92-95 kinda helped a lil bit but still runbles..if u guys fix it let me know ..pissing me off to!! did u check the throttle positioning sensor?? aight 1
Old Apr 2, 2005 | 07:05 PM
Evo-man@20psi's Avatar
Default Re: funny idle (1TwistedEG)
Probably the iac valve
Old Apr 3, 2005 | 07:44 AM
1TwistedEG's Avatar
well i dont have an extra tps sensor layin around...or i would
Old Apr 3, 2005 | 08:00 AM
EE_Chris's Avatar
If your idle likes to settle to 1500 rpm when the engine is warmed up, it sounds like the throttle is being held open or the throttle stop screw has been messed with. If the TPS was indicating a closed throttle (<.49v), but there was a vacuum leak present, your idle would hunt around. So it sounds like the throttle stop screw may have been messed with and has put the TPS on the line between indicating closed/open throttle which explains the hunting and why it settles to 1500 rpm.
What is your TPS voltage?
Old Apr 3, 2005 | 04:40 PM
1TwistedEG's Avatar
how do u check the voltage??
Old Apr 3, 2005 | 06:12 PM
nota-ex's Avatar
Did you try to clean off the IACV yet? I had the same problem (idled at lights between 800 and 1600 rpm)
I went to autozone and picked up a can of TB cleaner. You could see all the **** come right off of it. Popped it back on, took the car a few minutes to turn over, but it fixed it.
Old Apr 3, 2005 | 06:50 PM
1TwistedEG's Avatar
i'm gonna try that 2morrow when i get off work..thx
Old Apr 3, 2005 | 06:52 PM
nota-ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TwistedEG &raquo;</TD></TR><TR><TD CLASS="quote">i'm gonna try that 2morrow when i get off work..thx</TD></TR></TABLE>
It's a super tight fit. 12mm bolts. 1/2" works too. I'd reccomend using a wrench because unless you have a super-small ratchet you're going to have some issues.
Old Apr 3, 2005 | 06:54 PM
1TwistedEG's Avatar
yea..i alittle more room now with that ITR manifold on there...
jdmstyleg
Oct 15, 2009 06:55 PM
teal_deal
Jun 17, 2007 05:40 PM
jarvis199
Sep 13, 2005 07:20 AM
93civicjaydm
Jun 7, 2005 08:46 PM
DangBruhY
Dec 22, 2002 02:17 PM
