funny idle
Re: (ted)
Common problems with idling is the IAC (Idle Air Control Motor). It's on the back of the intake manifold and often times they are damaged when engines are taken out or shipped. I've seen this problem more than once and experienced it myself with my LS swap. Check to see if the housing where on the motor of the IAC is damaged, cracked, or if the connector is bad. If none of these things are present, trace the wires that are connected to the IAC and see if any are damaged. If you still cannot find anything, post back.
Tony
Tony
Re: (r3dh4tch)
check out the FITV on the b16 its right below the thorottle body...on the gsr, i have no clue where its at
https://honda-tech.com/zerothread?id=699787
we tried that 96ls and i've had the motor in the car for awhile and never had any probs. couple of months i guess...i couldnt find any vacum leaks or anything..sometimes it'll idle funny and sometimes it wont do it at all...wierd...but when it dont surge (idle up and down) it idles at like 1200.... im lost
Re: (1TwistedEG)
im experiencing the same problem as you right now.
i just did a B16A swap. my car idles and 3-3500k when cold and 2-2500 when warmed up.
ive replaced all vacuum lines, swapped in a new IAC, checked the FIT valve, put new TB gasket on, put a new intake mani gasket, checked the throttle cable tension, replaced the PCV for the hell of it, checked butterfly on TB for full closure, bled the coolant several times.
i still have the same problem after all of this.
its starting to really **** me off because i cant find the issue.
so any help to this would be great.
Re: (1TwistedEG)
well bleed your coolant first and see if that fixes it. then check the timy set screw where the throttle rotor sits. some times it needs to be turned 1 turn or so. its a 6mm allen key you use to adjust it.
Re: (1TwistedEG)
sup, i happen to have the same prob, as both of you . kinda sounds like the car angry !!..lol i have a 94 hatch dx and couple of weeks ago it started to do the same thing ....brrromm broomm ....after a couple of minutes it stops and idles around 1,000 rpm my engine is fine coolant ,check thermostat for the hell of it, all valves....iac...u name it .....nuthing.. but there was sumthing i never thought of that might be the problem..... '' i havent had a tune up'' maybe spark plugs ..wires , i dunno .i also played with the idle positioning screw found on top of the throttle body on the 92-95 kinda helped a lil bit but still runbles..if u guys fix it let me know ..pissing me off to!! did u check the throttle positioning sensor?? aight 1
Re: (1TwistedEG)
If your idle likes to settle to 1500 rpm when the engine is warmed up, it sounds like the throttle is being held open or the throttle stop screw has been messed with. If the TPS was indicating a closed throttle (<.49v), but there was a vacuum leak present, your idle would hunt around. So it sounds like the throttle stop screw may have been messed with and has put the TPS on the line between indicating closed/open throttle which explains the hunting and why it settles to 1500 rpm.
What is your TPS voltage?
Re: (1TwistedEG)
Did you try to clean off the IACV yet? I had the same problem (idled at lights between 800 and 1600 rpm)
I went to autozone and picked up a can of TB cleaner. You could see all the **** come right off of it. Popped it back on, took the car a few minutes to turn over, but it fixed it.
Re: (1TwistedEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TwistedEG »</TD></TR><TR><TD CLASS="quote">i'm gonna try that 2morrow when i get off work..thx</TD></TR></TABLE>
It's a super tight fit. 12mm bolts. 1/2" works too. I'd reccomend using a wrench because unless you have a super-small ratchet you're going to have some issues.
