TPS sensor or Ecu problem
Old Mar 21, 2005 | 08:15 AM
Catman316's Avatar
Default TPS sensor or Ecu problem
Hi, My car have a weird problem.
The oder day I was driving the car and i starts to act weird when I pressed tha gas , then the check engine light turned on. When I check the codes were codes 7, 14 and 22. TPS, IACV and oil press switch. I took the hazard fuse out and start the car again and everything was fine. The car did that 2 more times and when I reset the ecu the codes are gone. Today it did it again but just the TPS code came. I check the tps voltage and its fine, I checked the voltage manually opening the throttle and the voltage is constant and never drops, the I reset the ecu and its fine. Im not sure whats the problem, I thinks is the P28 ecu cause If it was the TPS the ligt would be on always. I need ur help to solve this problem, please let me know.
Thanks
Old Mar 21, 2005 | 06:13 PM
Catman316's Avatar
Default Re: TPS sensor or Ecu problem (Catman316)
bump for help
Old Mar 21, 2005 | 06:14 PM
eK9aT10pSi's Avatar
is it reading around ~.44v at idle ?
Old Mar 21, 2005 | 07:51 PM
Catman316's Avatar
Default Re: TPS sensor or Ecu problem (eK9aT10pSi)
yeap, and like 4.5 at WOT
95Sedan
Jan 14, 2014 12:13 PM
THA DOHCTOR
Engine Management and Tuning
Jun 17, 2012 04:06 PM
Horseofcourse
Apr 28, 2008 07:44 PM
Catman316
15
Apr 14, 2005 03:31 PM
AcCoRdStReEtRaCeR
Jan 30, 2003 08:08 PM
