For the light weight Nazi's in the group..
Yeah, i'm one to talk .... What ever can be replaced with something lighter and better i am all for it. So, with that being said....
Honda spent a but load of time and money on getting the R to be a light weight car why is the spare such a pos?
With that in mind all or at least most of us know that if we have a flat or blow out on the front we now have to change two tires instead of just the flat one because with a lsd you can not use the space saver spare on the front.. ( jacks with the lsd).
Not to mention the fact we are all running a 205/50/15 all the way around which just aggravates the size different between the spare and all of the other tires..
The solution......
1988-89 RX-7's come with a all aluminum 16"x4" spare which is damn light and very close to a 205/50/15 and can be used on the front of an ITR... It ( RX-& ) also has a very sexy all aluminum jack as well that fits perfectly where the stock Honda one fits.. In all its a weight savings over 25 lbs between the two ....
in the rear of the ITR..
Yuck... the stock spare..
As you can see not much diffrence between a 205 and this 16"
This with a spare and no air in it.... yep i was just to lazy..
the light *** jack....
not to bad for $10
My new use for the old spare...tire chuck...
As you can see it fits and works well. Sorry GS-R guys 5 lug only..
I am told that the early 1st gen RX-7 had a 4x100 alu spare as well but i have not seen one. i am also told that they are YELLOW.......
i got my spare from http://www.car-part.com
Good luck and happy hunting..
R
Modified by Rene M at 11:40 PM 3/23/2005
The solution......
not to bad for $10
R
And for you smart ***'s no the hold up stick did not come with it..........
Just to lazy the hold the carpet up by hand while it took the shot.
if you get a flat or watever on the front tires...i heard that you are supposed to always put the spare on the rear..because your factory lsd might get taco'd if you run one spare and one normal wheel on the front....correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Why are you doing events with a spare? </TD></TR></TABLE>
where does he say that he is?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo »</TD></TR><TR><TD CLASS="quote">if you get a flat or watever on the front tires...i heard that you are supposed to always put the spare on the rear..because your factory lsd might get taco'd if you run one spare and one normal wheel on the front....correct me if im wrong.
That's why he's running this spare. It's size is comparable to the regular size wheel and tire.
</TD></TR></TABLE>That's why he's running this spare. It's size is comparable to the regular size wheel and tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina »</TD></TR><TR><TD CLASS="quote">Doesn't, but what is the point if it is just for daily driving? It won't have any positive effect.</TD></TR></TABLE>
He's trying to help.
I do a lot of on road rallys and i am looking for a 50% cross weight with a 1/2 load fuel and in full street trim. I must carry any thing i may need on the road with me and right now my R is at 51.09 % cross weight with me as a driver and a car in street trim.
over all weight is 2736 lb..
Lf---874 rf-----876
lr---519 rr----441
i am all most there...
This is on stock shocks and no coil overs..
I wish i could get my track car to have #'s like this..
Lf---874 rf-----876
lr---519 rr----441
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M »</TD></TR><TR><TD CLASS="quote">i am all most there...
This is on stock shocks and no coil overs.. </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1185665
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Willard »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1185665</TD></TR></TABLE>
Yeah, i just saw that...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black R »</TD></TR><TR><TD CLASS="quote">I just use an extra itr gunmetal wheel as spare..... it fits over spoon calipers.
Does it fit under the trunk liner?
</TD></TR></TABLE>Does it fit under the trunk liner?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">i wish my car came with a spare</TD></TR></TABLE>
Mine didn't come with one either.
Lf---874 rf-----876
lr---519 rr----441
Cool. I do some of those, but they are not so legal yet fun Poker Runs with spirit.
Lf---874 rf-----876
lr---519 rr----441
</TD></TR></TABLE>Cool. I do some of those, but they are not so legal yet fun Poker Runs with spirit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut »</TD></TR><TR><TD CLASS="quote">Does it fit under the trunk liner?</TD></TR></TABLE>
Yes, just like stock..
