*TAKES FOREVER FOR CAR TO HEAT UP AFTER SWAP*
Old Mar 20, 2005 | 07:25 PM
Spence's Avatar
Default *TAKES FOREVER FOR CAR TO HEAT UP AFTER SWAP*
Hey guys i put a ls in and its taking like 20 min of freeway driving to get the car to start blowing warm air and temp gauge to get to normal what could be wrong?
Old Mar 20, 2005 | 07:26 PM
b18_4door's Avatar
thermostat??
Old Mar 20, 2005 | 07:44 PM
2point2's Avatar
check your coolant level..
Old Mar 20, 2005 | 07:46 PM
Kyles ej1's Avatar
Default Re: (2point2)
doing THE TITLE IN ALL CAPS IS AGAINST THE RULES
Old Mar 20, 2005 | 07:50 PM
eK9aT10pSi's Avatar
Default Re: *TAKES FOREVER FOR CAR TO HEAT UP AFTER SWAP* (Spence)
how old is the coolant, sounds like either the system needs to be flushed or the thermostat went bad and stuck open.
Old Mar 20, 2005 | 07:52 PM
Spence's Avatar
umm its new coolant hence i just did the swap
Thermostat not sure cause would it ever warm up?
Old Mar 20, 2005 | 07:54 PM
Hapexamendios EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinister6 &raquo;</TD></TR><TR><TD CLASS="quote">Well, my old car shoot flame out all the time, but then its turbocharged.
just crank up your compression </TD></TR></TABLE>
Old Mar 20, 2005 | 08:31 PM
Spence's Avatar
so i take it if a therm is stuck open the car will still heat up but take forever? I thought the only way a thermo can go bad is if the car is over heating ill check into this tomorow
Old Mar 20, 2005 | 08:52 PM
2point2's Avatar
Default Re: (Spence)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">umm its new coolant hence i just did the swap</TD></TR></TABLE>
<u>hence</u> check the coolant level again and make sure the cooling system is 100% bled.
Old Mar 21, 2005 | 02:19 PM
Spence's Avatar
Well i fixed the problem the dumb **** i bought the motor from did not even have a thermostat in the motor at all i was shocked to find that there was not one there!!!
So now the car heats up really quick thanks for the help guys spencer
mikeryan161
Dec 16, 2012 03:36 PM
PphamEK
Feb 17, 2009 09:34 AM
nonhondaman
Apr 17, 2007 07:26 PM
importfanatic17
Jan 4, 2007 09:14 PM
DB1_559
Jul 24, 2006 08:56 AM
