94 GSR swap into 98 ex civic
Old Mar 20, 2005 | 05:49 PM
moto1320's Avatar
Default 94 GSR swap into 98 ex civic
So, I searched and searched to start....
94 GSR swap into 98 civic ex. Anyway, never gone the other way with OBD before. So, I have OBD2 alt and injectors off of a previous ITR swap to use. I'll need the OBD2 dizz, does it have to be B series or will the D16 work. Anything else I'll need? I was just going to use the ex civic harness. I have a spare JDM type-R ECU that I will run in the beginning. (Putting in CTR cams and p73-00 pistons)
Old Mar 20, 2005 | 08:51 PM
hatchi's Avatar
Default Re: 94 GSR swap into 98 ex civic (moto1320)
looks like you answered your questions already.
you will need 99-00 si T bracket
front brackets
you will reuse your stock upper mounts/brackets
Old Mar 21, 2005 | 12:31 PM
moto1320's Avatar
got all the hardware too, just worried about the electronics...should have been more specific. What about that D16 OBD2 distributor? Usable or does it have to be B-series. All plugs/sensors compatiblle? I'm thinking so since I just put a 98 engine into a 94 car. They were both Tegs though.
Old Mar 21, 2005 | 08:07 PM
moto1320's Avatar
bump
Old Mar 22, 2005 | 12:37 AM
DunDaDa_EK9's Avatar
i think it doesn't work becuz the bracket on the intake cam side wouldn't mount on it, so u need a b-series vtec dizzy.
Old Mar 22, 2005 | 12:51 AM
ekb16's Avatar
u can use ur d series dizzy plug and make a obd2 to obd1 dizzy convserion
Old Mar 22, 2005 | 01:17 PM
moto1320's Avatar
would I want to do this if I was running OBD2 ECU and wiring harness?
Old Mar 22, 2005 | 05:28 PM
moto1320's Avatar
up
Old Mar 25, 2005 | 11:45 AM
moto1320's Avatar
up
Old Mar 25, 2005 | 11:52 AM
dantastic's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">u can use ur d series dizzy plug and make a obd2 to obd1 dizzy convserion</TD></TR></TABLE>
if he's going to be runnning a obd2 ecu, he'll need an obd2 dizzy b/c it has more sensors (im 90% sure... anyone want to comfirm?)
also, the obd2 ecu will also look for the ckf sensor on the oil pump, which the obd1 motor doesnt have. (again, can someone confirm this? i've heard that some jdm obd2 ecus dont look for certain obd2 usdm sensors)
Old Mar 25, 2005 | 11:54 AM
IHateJDM's Avatar
Default Re: (moto1320)
b series dizzy, and stay obd2. more pain in the *** when wiring the motor, but there is a reason honda added all those sensors.
Old Mar 25, 2005 | 12:55 PM
ReDHaTcHyGuy's Avatar
Default Re: (dantastic)
u can just use the obd1 dizzy and repin the plug for the dizzy , i think u only have to swap 2 wires.. u don't need a 0bd2 dizzy
Old Mar 26, 2005 | 04:41 AM
moto1320's Avatar
If I can't use the D series dizzy, then I'll have to get one anway so I'll buy an OBD2 one. I think the only B series one I have left is OBD0. thanks for the help. I work for Acura during the day so I can get a type-r wiring harness for cheap anyway. Should I just do this? I'm scrapping the GSR manifold so no butterflies. I have little down time between my car and the other customers projects right now so time is worth more to me than a little extra cash. I need to knock this out in a day or less. that's no problem for me with the swap but I don't want to have a bunch of electrical gremlins. I sold my other car so i have to drive home the same day.
Old Mar 26, 2005 | 04:55 AM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
also, the obd2 ecu will also look for the ckf sensor on the oil pump, which the obd1 motor doesnt have. (again, can someone confirm this? i've heard that some jdm obd2 ecus dont look for certain obd2 usdm sensors)</TD></TR></TABLE>
like he said. you might have this cel on this sensor.
Riptide101
Jul 17, 2017 09:35 AM
fromthesun_93
Jan 10, 2012 06:34 AM
LastGenEK
14
Jan 30, 2008 03:00 PM
UltRaH22
Apr 2, 2004 11:05 AM
hobo79
Aug 26, 2001 02:27 AM
