Check Engine Light???
Old Mar 19, 2005 | 10:23 PM
rhdune16's Avatar
Default Check Engine Light???
I was cruising around today and out of no where my CHECK engine light came on. So I came home and checked for the code. The code came out to be 92 which is Evaporative Emission System Insufficient Flow Purge. I just wanna know what the hell is that. I tried searching but didn't find it. Someone please help me out. Also if it helps I just got the manual swap done 2 days ago. Don't know if that's what caused it, but let me know if you guys have an idea of what it means... Thanks
Old Mar 19, 2005 | 10:45 PM
accordselux's Avatar
Me Gusta History
Default Re: Check Engine Light??? (rhdune16)
bump cause I helped get the code out of it and I want to fix the damned thing...
Old Mar 19, 2005 | 10:55 PM
Intense3.2's Avatar
Default Re: Check Engine Light??? (accordselux)
Check your charcoal cannister... a vaccume line might not be hooked up, or you might have cracked it.
Old Mar 19, 2005 | 11:17 PM
rhdune16's Avatar
where is the charcoal canister
Old Mar 19, 2005 | 11:30 PM
Intense3.2's Avatar
Default Re: (rhdune16)
It's located on your firewall right below the fuse box... its a big cylinder with 2 vaccume lines coming out of the top.
Old Mar 20, 2005 | 07:50 AM
rhdune16's Avatar
Does anyone know what else it might be???
Old Mar 20, 2005 | 02:36 PM
rhdune16's Avatar
BUMP
Old Mar 20, 2005 | 02:45 PM
raceACCORDingly's Avatar
did you find where the evap cannister is?
maybe after the manual swap they didnt hook it back up.
Old Mar 20, 2005 | 02:56 PM
rhdune16's Avatar
Yeap i looked at the charcoal canister and all the hoses are hooked back up. The engine light came on 1 day after driving and it was a lot of driving
dwf
Mar 11, 2009 12:26 PM
importdude2000
Jul 17, 2004 12:53 PM
acura0gsr0ntegra
Sep 15, 2003 09:49 AM
TheOne
Sep 15, 2002 02:52 PM
ITR 01-0840
Oct 4, 2001 04:13 PM
