b18c5 swap, need obd1/obd2 jumper
Old Mar 19, 2005 | 07:49 PM
Hatch-Si-93's Avatar
Default b18c5 swap, need obd1/obd2 jumper
soon or later, i will swap a 97+ b18c5 to my 93 hatch si. the engine comes with the ecu, i dont know wat kind of jumper should i use anyone knows???
Old Mar 19, 2005 | 08:22 PM
ekb16's Avatar
im not sure but im thinking u will need a OBD2a to OBD1..
Old Mar 19, 2005 | 08:33 PM
Default Re: (ekb16)
http://cgi.ebay.com/ebaymotors...33596
thats wat i found on ebay, is one of those?
Old Mar 19, 2005 | 09:00 PM
Buzzo's Avatar
Default Re: b18c5 swap, need obd1/obd2 jumper (Hatch-Si-93)
I'd chip the stock computer and plug in at the shock tower connectors. Much easier and less problematic
Old Mar 19, 2005 | 09:43 PM
93Civac's Avatar
Use the harness on the B18 and it will be plug directly into the chassis harness. Then just chip your p28 (im quessing thats what in the 93 si) and your done.
Old Mar 19, 2005 | 10:29 PM
hatchi's Avatar
what year is the c5 swap? just use an obd2 gsr wire harness it will be plug n play you will need to add knock sensor wire. Use a chipped p28 which can also eliminate knock sensor if you like
Old Mar 19, 2005 | 11:40 PM
Slopoke's Avatar
Default Re: (Hatch-Si-93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch-Si-93 &raquo;</TD></TR><TR><TD CLASS="quote">http://cgi.ebay.com/ebaymotors...33596
thats wat i found on ebay, is one of those?</TD></TR></TABLE>
No that harness is for using an obd1 ecu in an obd2 car.
If you wanted to run the stock itr ecu, then you need an obd1 to obd2A jumper harness.
Old Mar 20, 2005 | 07:21 AM
Default Re: (Slopoke)
thanks to all of u, i already fournd a jumper that i need:
http://cgi.ebay.com/ebaymotors...WA:IT
i willl use the ITR ecu that comes with the 97 and up type r engine.
if my swap wil be smoothly done and the car runs great, i will get another chipped obd1 ecu:
http://cgi.ebay.com/ebaymotors...&rd=1
the engine comes with everything i need, and i heard b18c5 is direct bolt in 92-95 civics, all i need is a obd1/obd2 jumper. i think i am all set for now. anything else i need???
sh4mr0ck
Jun 20, 2009 11:51 AM
EG8GSR
Oct 25, 2007 10:50 AM
OTI-
Dec 20, 2006 04:30 PM
93civicEX
Dec 26, 2003 01:01 PM
43MA
Nov 6, 2002 08:46 PM
