HELP!!! car idle
Old Mar 18, 2005 | 11:26 AM
b16crx88's Avatar
Default HELP!!! car idle
i have a ls vtec swap in my 88 crx and i parked my car for the winter and now when i drive it my idle is 3000 till it warms up and idles down to 1500. during the summer last year it idled at 2000 till warm then dropped to the normal 1000. as of yesterday my idle is pulsing at a range of 300-500rpms. obviously this is not normal. PLEASE PROVIDE ANY IDEAS TO FIX MY PROBLEM!!
Old Mar 18, 2005 | 11:58 AM
Gumbey75's Avatar
Default Re: HELP!!! car idle (b16crx88)
try cleaning your IACV in back of your intake masnifold. take some carb cleaner and clean the screen. then adjust the idle screw on you TB.
Old Mar 18, 2005 | 12:22 PM
egtwincam's Avatar
if you have a fast idle valve. its right below the throttle body. take it apart(3screws) the plunger may have come apart. also check that you routed your coolant lines from the fast idle valve to the iacv correctly.
Old Mar 18, 2005 | 01:53 PM
jsw_1986's Avatar
Default Re: (egtwincam)
I had the same problem with my old civic. it was exaclty what egtwincam had said. there's that senser right below the TB and one of the screws inside had come loose. hope you get it fixed
Old Mar 18, 2005 | 05:26 PM
91_HB's Avatar
I just finished solving a similar problem on my civic. when u start yur car and it revs up to 3grand, grab the pedal with yur hand and pull the pedal backwards (opposite of accelerating). If this works try spraying sum penetrating oil on it. This may not b the problem but its worth trying because it isnt very hard to check.
Old Mar 18, 2005 | 05:29 PM
91_HB's Avatar
I just finished solving a similar problem on my civic. when u start yur car and it revs up to 3grand, grab the pedal with yur hand and pull the pedal backwards (opposite of accelerating). If the car idles down try spraying sum penetrating oil where yur throttle cable connects to the throttle body. This may not b the problem but its worth trying because it is very easy to check.
Old Mar 18, 2005 | 05:30 PM
doublethink's Avatar
bens idle guide has it all.
http://www.ef-honda.com/ben/Badidle.php
search next time.
Old Mar 19, 2005 | 11:14 AM
b16crx88's Avatar
i have talked to people in town about it and i have been told it may need to be tuned on wideband to diagnois this problem. does anybody think that is neccsary?
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
PWRDbyHseries
Oct 18, 2006 05:44 PM
hondachris1994
Mar 3, 2006 06:49 AM
94SHOWLS
Feb 17, 2005 12:31 PM
killa_lude
Aug 16, 2003 08:33 AM
