pcv system upgrade
Old Mar 17, 2005 | 07:08 PM
sickerhatch's Avatar
Default pcv system upgrade
Well I've heard that the pcv system on Honda's is not very good.I was wondering what are some ways to get better venting of my crank case.
Also i had this idea and yes it sounds weird/ghetto and keep in mind this is all theary but what if you drilled another hole in the black box on the back of the block and added a tube and just vented it to the atmosphere.Then you would still have the vacuum pressure relief at idle and more venting at wot.
What do you guys think any one see any problems with this?
Old Mar 17, 2005 | 08:05 PM
Default Re: pcv system upgrade (sickerhatch)
also you would have to add a second pcv valve to the new hose
Old Mar 17, 2005 | 10:24 PM
S2 INSIDER's Avatar
look into a pan e-vac
Old Mar 17, 2005 | 10:26 PM
S2 INSIDER's Avatar
you can also add another outlet on your valve cover
slaquers
May 14, 2011 11:34 AM
mr_gs-r
Dec 7, 2007 10:04 PM
the.hamburglar
Apr 23, 2007 08:34 PM
marcin
20
Nov 20, 2005 10:55 PM
sickerhatch
Mar 18, 2005 05:07 AM
