constant vtec
Old Mar 17, 2005 | 06:57 AM
jessej's Avatar
Default constant vtec
Frankenstein motor in a 99 hx civic has a constant output of 14.0 volts to vtec plus hits a rev limitor at 6000. it does not redline just acts as if somethings holding it back.PLEASE HeLp. Thanks
Old Mar 17, 2005 | 07:00 AM
94sol_vtec's Avatar
Default Re: constant vtec (jessej)
problem with the ecu?? try out a friends with the same vehicle in yours and see if it helps - - if it does, then u know thats the problem...
u should get that fixed though - - its gonna suck for gas mileage and wear on your engine...
sikek's Avatar
what engine harness are you using?
Old Mar 17, 2005 | 07:09 AM
jessej's Avatar
Default Re: constant vtec (94sol_vtec)
I am using a 99 si ecu and wiring
Old Mar 17, 2005 | 07:23 AM
2lua's Avatar
check you tps and map sensor see if it got switched.
Old Mar 17, 2005 | 07:42 AM
jessej's Avatar
Default Re: constant vtec (2lua)
Already checked, it is correct and according to helm and chilton they are both reading accurate volts and ohms.thanks
Old Mar 17, 2005 | 07:50 AM
b204dr's Avatar
which block if your running a b20 vtec best to run a gsr ecu - your fuel map on the 99/00 si ecu is kind of far off for a b20 ! i ran the si ecu on myne same prob- ran gsr ecu- ran fine!
Old Mar 17, 2005 | 08:30 AM
jessej's Avatar
Default Re: (b204dr)
Were all the pin outs and plugs on the si harness the same for the gsr? What year also. Thanks
Old Mar 17, 2005 | 08:34 AM
IHateJDM's Avatar
Default Re: (jessej)
The VSS sensor is in a diff place on the p28 and p72. Also, with the p28 you can ground your vtec oil pressure switch to the motor, but the p72 looks for it at A26 i think. Search for the pinouts and compare. I bet that's your problem.
Old Mar 17, 2005 | 08:38 AM
jessej's Avatar
Default Re: (93delslo)
The vss is not hooked up b/c he used a 91 ls tranny with cable clutch and that sensor is mechanical compared to an electrical one with th si
Old Mar 17, 2005 | 08:42 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jessej &raquo;</TD></TR><TR><TD CLASS="quote">The vss is not hooked up b/c he used a 91 ls tranny with cable clutch and that sensor is mechanical compared to an electrical one with th si </TD></TR></TABLE>
You might want to consider converting to OBD0. Maybe someone else has some ideas, I'm out.
Old Mar 17, 2005 | 08:45 AM
jessej's Avatar
thanx for the info, anything else willbe helpful
Old Mar 18, 2005 | 05:15 AM
jessej's Avatar
y
Old Mar 18, 2005 | 07:46 PM
jessej's Avatar
bump
Old Mar 20, 2005 | 06:22 AM
jessej's Avatar
q
victor559
11
Jul 3, 2005 10:18 PM
turbo_smallblockchevy
Jun 23, 2005 09:47 PM
iRIDEdumped
32
Apr 25, 2005 06:34 PM
