Replaced timing belt and now odd idle.
Old Mar 16, 2005 | 07:07 PM
.Ry's Avatar
.Ry
Default Replaced timing belt and now odd idle.
Thanks for looking at this post. As it reads monday I had my timing belt and water pump replaced on my 1995 Honda Civic D15 16 valve. Immediatly after I noticed the ide was different, instead of being constant as it was before the service was it seem to go very low and go up a little bit and back down but the engine seems to vibrate instead of just idle. I cant explain it but its there. The gearheads at my work says he may not have lined up the gears when he replaced the belt. I have tried to reset the ECU, check the coolant level, spark plugs and wires seem fine. If you have any ideas as to why this is happening please let me know ASAP as im taking it back in tommorow morning.
Old Mar 16, 2005 | 07:11 PM
JDMH22HATCH's Avatar
Default Re: Replaced timing belt and now odd idle. (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">The gearheads at my work says he may not have lined up the gears when he replaced the belt. </TD></TR></TABLE>
UUmm yeah, take it back, and DON'T let that guy touch your car............ever. Try lining everything up to TDC and make sure everything is lined up; ie: crank pulley, cam gear, etc. If everything IS lined up, try doing a valve adjustment and see if the noise still persists
Old Mar 16, 2005 | 07:13 PM
.Ry's Avatar
.Ry
Default Re: Replaced timing belt and now odd idle. (JDMH22HATCH)
well it doesnt so much make a noise as it surges at a low idle i guess, I hate that I dont know how to explain I just know its not the same, I have searched this site and have taken all the old advice into account but its still there.
Old Mar 16, 2005 | 07:18 PM
Malakai's Avatar
prob didnt line up the cam gears right.
Old Mar 16, 2005 | 07:21 PM
.Ry's Avatar
.Ry
Default Re: (Malakai)
thanks so far, more of what i was thinking thats a plus. I just bought this car and not to bad so far, this just pisses me off all excited about getting a nice car then this crap happens. If anyone reading this has an idea about what it could be post it.
Old Mar 16, 2005 | 08:22 PM
.Ry's Avatar
.Ry
bump?
Old Mar 17, 2005 | 09:11 AM
censurebush's Avatar
From: everything for everyone, and nothing for ourselves
f*ck*d up idle 'eh?
take it back to the mechanic bro ... they made the problem- they fix the problem.
Old Mar 17, 2005 | 01:31 PM
esohsee's Avatar
Default Re: Replaced timing belt and now odd idle. (censurebush)
everyone saying misaligned timing belt... check it out and let us now if thats it...
good luck
Old Mar 17, 2005 | 01:34 PM
IHateJDM's Avatar
Default Re: Replaced timing belt and now odd idle. (esohsee)
timing belt is off a tooth on the cam gear(s). line the crank up to tdc and see if the cam gear(s) are lined up correctly.
Old Mar 17, 2005 | 02:23 PM
.Ry's Avatar
.Ry
Default Re: Replaced timing belt and now odd idle. (93delslo)
you were all right thanks alot guys she purs like a kitten.
gokblok
Aug 1, 2013 04:20 PM
RockLee`
11
Feb 2, 2007 10:03 PM
ShinobiLude
Nov 8, 2006 08:40 AM
llevity
Jul 12, 2005 02:39 PM
