Fuel injectors foir an OBD-I car, but OBD-II block/head
Old Mar 16, 2005 | 05:20 PM
NoVALude's Avatar
Default Fuel injectors foir an OBD-I car, but OBD-II block/head
Anyone have any ideas/suggestions re: FI's? I have an '92 Lude now with an H23. I am planning on pulling the H23 and putting in a 98 block with a 99 head. Basically my car is OBD-I now and I have been told that I should stay this route as it is less of a headache. However, what do I use for injectors? I realize that the intake mani's are the same size, and I will get headers for 97-up VTEC, but which injectors/ECU do I use? If the goal is to stay OBD-I, would I use the P28 (and maybe Hondata?) and OBD1 injectors (i.e. pre-96) ? Any help is appreciated.
Old Mar 16, 2005 | 06:55 PM
Boost3d22's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (NoVALude)
i am having this problem as we speak, i have a obd2 97 h22 with a p28(obd1) ecu in it for hondata. i had to buy a resistor box and clips, used peak and hold (low impedence) injectors from a dsm and it works fine. the p28 cannot work with the stock high impedence injectors (saturated)
Old Mar 16, 2005 | 08:12 PM
satan_srv's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (Boost3d22)
match ecu, injectors, fpr and resistor box (if required)
it's all h22...just choose a fuel setup and be consistent
Old Mar 17, 2005 | 06:28 AM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost3d22 &raquo;</TD></TR><TR><TD CLASS="quote">i am having this problem as we speak, i have a obd2 97 h22 with a p28(obd1) ecu in it for hondata.</TD></TR></TABLE>
So your car was already OBD-II? and you wanted to use the P28 (OBD-I)
Since my car is already OBD-I ( I am guessing that I do not need a resistor box)
I am thinking of going with peak/hold inj. (345cc), and using the p28 with Hondata.
Any comments?
Old Mar 17, 2005 | 08:59 AM
gerhard's Avatar
Anyone know what the cc rating on the stock injectors from a 93 H22A JDM Prelude would be?
Old Mar 17, 2005 | 10:43 AM
NoVALude's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (gerhard)
this thread does not say USDM vs. JDM, but: https://honda-tech.com/zerothread?id=549372
I would say 345cc
Old Mar 17, 2005 | 10:52 AM
IHateJDM's Avatar
4th gen h22 (93-96 jdm or usdm) 345cc
5th gen h22 (97-01 jdm or usdm) 290cc
Old Mar 17, 2005 | 11:29 AM
Ross2852's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (93delslo)
does the peak and hold vs saturated have any effect over the ecu... or is it just the size of the injectors that matters
Old Mar 17, 2005 | 11:31 AM
IHateJDM's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (Ross2852)
no effect on the ecu, but with the 4th gen injectors, you need a resistor box so the ecu reads the correct resistance. Otherwise it won't work.
Old Mar 17, 2005 | 02:35 PM
fastludeh22's Avatar
ok guys, you can use saturated injectors w/p28, just dont use the resistor box. however 90% of bigger injectors are peak and hold and require resistor box in any honda. 4th gens already have them.
you will NOT want 97+ injectors, you will want to use ALL 4th gen parts on your h22 and car, ie oil pump and dist., and header. this is not the only way, but is easiest and the best.
Old Mar 17, 2005 | 03:24 PM
NoVALude's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (fastludeh22)
so when I look at getting injectors, I should go for the 345cc peak hold OBD-1 style?
Old Mar 17, 2005 | 03:27 PM
IHateJDM's Avatar
someone correct me if i'm wrong, but I think it's more important to match injectors to your ecu than to match them with your head. Worst case scenario is you run rich.
Old Mar 17, 2005 | 03:48 PM
NoVALude's Avatar
if using the P28, then go with OBD-I injectors right?
Old Mar 17, 2005 | 05:29 PM
IHateJDM's Avatar
a chipped p28 can run any fuel map you want, but is most likely the obd1 version of the p13 maps. you just need to know what the chip is for, and match your injectors to that.
Old Mar 18, 2005 | 04:49 AM
NoVALude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93delslo &raquo;</TD></TR><TR><TD CLASS="quote">no effect on the ecu, but with the 4th gen injectors, you need a resistor box.....</TD></TR></TABLE>
resistor box? you mean as in the resistor box in Lude's that are OBD-I right?
Old Mar 18, 2005 | 05:28 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoVALude &raquo;</TD></TR><TR><TD CLASS="quote">
resistor box? you mean as in the resistor box in Lude's that are OBD-I right? </TD></TR></TABLE>
yes. all resistor boxes are the same for hondas. I went to a junkyard and got one off an old wrecked DA teg.
Old Mar 18, 2005 | 08:33 AM
NoVALude's Avatar
good to know I already have and that it's one less part I will have to buy
Old Apr 8, 2005 | 11:29 AM
snowblind7x's Avatar
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">match ecu, injectors, fpr and resistor box (if required)
it's all h22...just choose a fuel setup and be consistent</TD></TR></TABLE>
what's fpr? fuel pressure regulator?
Modified by snowblind7x at 12:43 PM 4/8/2005
Old Apr 8, 2005 | 11:42 AM
Default Re: Fuel injectors foir an OBD-I car, but OBD-II block/head (snowblind7x)
*edit*oops, double posted, my bad.
H22 SL33P3R
Nov 4, 2014 10:52 AM
jtkc
Oct 16, 2013 05:48 AM
dohcem1
Jan 15, 2009 11:05 PM
_Cyclone_
10
May 26, 2005 05:10 PM
cccya
Mar 13, 2003 01:38 PM
