DSM's flooding engine on startup...
Is it common for larger injectors to flood the engine during startup? My D16Y8 starts on the first rotation or sometimes gets too much fuel and dies and I have to restart it. Is this a common problem for those who use larger injectors? Is there a solution?
EDIT: Using a chipped P28 and Hondata S200b for management, resistor box wired into the injectors properly. Runs perfect the rest of the time.
Modified by CycloneBlue_1.6EL at 5:24 AM 5/26/2005
Re: DSM's flooding engine on startup... (CycloneBlue_1.6EL)
what are you using to control the injectors? if you just stuck them on there with out some kind of fuel controller, you will flood the motor. heres an example of what i mean.
ecu tells stock honda 240cc injectors to shoot lets say 20%
if you just slapped the dsm injectors on, the ecu will tell the dsm injectors to shoot 20% too but it will be according to the dsm size.
Re: DSM's flooding engine on startup... (Luserkid)
cant u jus get a resistor box? or am i worng.. cause thats what i got.. but i havent pu nething on my car yet
Re: DSM's flooding engine on startup... (egcivic)
I've got a chipped P28 with Hondata s200b controlling everything, resistor box wired in. I should have been more specific. It runs perfect the rest of the time, just on start up because I think the ECU is telling the injectors to fire too much fuel in while cranking.
My Uberdata setup was the same way, I just had to hold the throttle open slightly while cranking. You kinda get used to it I guess.
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL »</TD></TR><TR><TD CLASS="quote">I've got a chipped P28 with Hondata s200b controlling everything, resistor box wired in. I should have been more specific. It runs perfect the rest of the time, just on start up because I think the ECU is telling the injectors to fire too much fuel in while cranking.</TD></TR></TABLE>cranking MS needs to be trimmed....
if you had a Power FC you could do that with the commander immediately
Re: DSM's flooding engine on startup... (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch »</TD></TR><TR><TD CLASS="quote">cranking MS needs to be trimmed....
I wonder if that's something the tuner can do with the Hondata...
MiG-21 superfan
I wonder if that's something the tuner can do with the Hondata...</TD></TR></TABLE>
yes, definately...
yes, definately...
red civic standard
10-31-2004 02:25 AM
