removing ARP studs, and installing an oil catch can
Old Mar 16, 2005 | 06:20 AM
pendejon's Avatar
Default removing ARP studs, and installing an oil catch can
Wassup guys.
In my house i have a block with ARP headstuds, which i would like to remove and put into another block. now, my friend says to thread on 2 nuts, the 1st upside down, and then the 2nd normally and have them really tight against each other, so I can unthread the head studs. does this sound appropriate to you guys?
Also, this is a d16 im working on, and I have an oil catch can for it. I have seen a motor built by Endyn where they tapped into the rear of the block to have a spot for the oil catch can to run to. Any one know how I would go about getting this done?
Thanks for all the help.
Old Mar 16, 2005 | 07:20 AM
PrettyLude's Avatar
do a friendly search for catch can or pcv
the double nut method will work great, you must have the older style arp studs
jel002
Nov 7, 2009 03:05 PM
jaron_cc
Apr 3, 2009 07:33 PM
HamiltonRex
Jul 5, 2006 06:55 PM
turbotime
Oct 19, 2005 06:31 PM
LSEGHATCH
Aug 19, 2005 10:53 AM
