engine stalling on me when I'm in neutral
Hi everybody,
I have a 95 SI that keep dying on me when I'm riding in neutral. It not giving any error code at all. Just the battery and oil light comes on when it die. It usually occur when I coming to a stop sign and I shift it to neutral. If anyone can point me toward fixing this problem, I would appreciate. The car has 166K miles. I recently changed the water pump, timing belt, all the drive belt and fuel pump. I'm at a lost right now. Could be possible be the MAP sensor?
TIA
Tony
TIA
Tony
Is it stalling on you when you have the clutch pushed in and just rolling, or when the car is actually in neutral and the clutch is out, or both?
EDIT-- Typing owns me
i have that problem from time to time on a jdm h22. I can't crank it right away either, I have to give it at least 10 secs first. otherwise a few cylinders will fire and it'll die again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2gn9gencevg »</TD></TR><TR><TD CLASS="quote">Try a compression test to see if your valves are bent.</TD></TR></TABLE>
That would make his car stall only when the clutch is down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx »</TD></TR><TR><TD CLASS="quote">
No, when I had bent valves my car would stall in nuetral weather the clutch was up or down.
</TD></TR></TABLE>No, when I had bent valves my car would stall in nuetral weather the clutch was up or down.
I know this is a long shot considering the fact that it’s been years since this post but any chance on an update? Having the same exact issue. H22 swap ‘93 prelude. PLEASE HELP
category5 SI
Jun 26, 2008 09:17 PM
nk2k2
Jul 22, 2006 10:14 AM
